Haier HD451E Dehumidifier Logo
Posted on Jun 30, 2010
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Josephine Maxwell
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 08, 2014
Josephine Maxwell
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
15637
Points
We have an E2 message on this and it is hooked to a hose into a drain tube so it has nothing to do with the bucket placement.
Anonymous
Level 1:
New Friend:
  • Posted on May 20, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
15637
Points
  • Rachael Nicole
    Rachael Nicole Oct 17, 2018
    I have the same problem right now it was working fine I empty the bucket put the bucket back in and the E2 keeps coming up. Ive cleaned the filter, the bucket, tried different outlets and seeing as its about a year old and the small one cost me almost $350 im not happy at all. And dont know who to call
4 Related Answers
Anonymous
  • 121 Answers
  • Posted on Jun 24, 2008
SOURCE: GE dehumidifier light says bucket is full but it isn't
Try feeling both sides of the outside of the bucket and make sure the bucket is flush with the dehumidifier. If one side is sticking out more than the other it may notbe engaged correctly which will cause a full bucket notification. If everything checks out ok there try takng the bucket out and push in on the button that the lever from the bucket engages on at the dehumidifier. If the light turns off after you push on the red button that means the bucket is not engaging correctly. If the red light stays on and it doesnt make a difference he button sensor may be defective. If you found this solution helpful please rate it.
Thanks - Tech101
Anonymous
  • Posted on Sep 13, 2011
SOURCE: haier dehumidifier model de45ej-t What does
Dehumidifier (DE45EJ-L) shows only E2 on the display -- no "buttons" work. Had been working perfectly -- we turned it off a few days ago. Any suggestions??
Anonymous
  • 4736 Answers
  • Posted on Apr 14, 2011
SOURCE: Hi, When I tried to
Your model is no longer in manufacture or available. However, I was able to locate the Owners Manual for you. It does not list a CH 01 Error Code, but does list other reasons why your unit want turn ON.
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=LHD45EL&matchedModelCode=1000001989&searchEngineModelCode=LHD45EL&targetPage=support-product-profile&initialTab=documents#
In the past, I have recommended turning the Master ON/OFF Switch to OFF and unplugging the unit for 12-15 minutes. This will give the unit time to hopefully, reset itself. Then Plug the unit back in and turn the Master ON/OFF Switch to ON. Set the humidity control as you normally would. If it successfully reset itself, it should operate normally.
If you continue to have problems, contact LG Customer Support at 800-243-0000.
Hope this helped you to solve the problem.
David Shaub
  • 2994 Answers
  • Posted on Jan 31, 2009
SOURCE: I have a 45 pint
It's for when you dump the bucket. You put the cup in to catch the drips while you're dumping it.
Haier Dehumidifier says 'bucket full'.
It sounds like the switch needs to be replaced or adjusted.
https://www.google.com/search?q=Haier+Dehumidifier+says+bucket+full
Need model number. That is needed in all Fixya questions.
https://www.google.com/search?q=haier+dehumidifier+parts+list
My Haier dehumidifier has the bucket full light on and won't reset. It's only a month old. I tried unplugging, resetting and i'ts still stuck on bucket full. Any ideas on how
sorry to say but the bucket level sensors on these tend to be a bit tricky , it seems theres two possible holes the piviot point for float can go in , only one is correct for sensor to hit right , but both allow float to swing , and there not marked either
Dehumidifier not turning on showing an e2 code
Lisa, unfortunately, Haier for whatever reason does not list what error codes mean, in their Owners Manual. You will have to contact Haier Customer Support 1-877-337-3639 for that.
In the meantime, turn the ON/OFF Switch to OFF and unplug the unit for 15 minutes. Then, plug the unit back in and turn the ON/OFF Switch to ON. Hopefully, during that 15 minute timeout, the electronics reset and reverted back to the original factory settings. If they did, you can set the controls as you like.
Hope this helps you and thanks for choosing FixYa.
4helpful
2answers
My dehumidifier is showing an E2 code on it. It is a brand new haier, can you help me out with this problem?
E2 Code indicates a Sensor Error automatic shutdown. To find out which sensor it is you will have to call Haier Customer Support 1-877-337-363.
In the meantime, turn the unit OFF & unplug it for 15 minutes. Then plug the unit back in and turn ON. ON. Hopefully the unit reset itself and reverted back to the original factory settings. And you can set te humidity extraction level where you desire. If the error code reappears, definitely contact Haier, as youtr unit is still under warranty.
Unit does not start, shows E2 error, can you help on what that code means and resolution
I have searched and searched and have not been able to find an Owner's Manual for your model Amcor Dehumidifier. I did discover that Haier and Fredrich both have similar models, So similar, I suspect Haier manufactured them. But, neither the Haier nor the Fredich's unit have any information concerning Error Code 2. Plus, the ratings for your Amcor model were not very good. Seems that Amcor is riddled with problems.
In any event, lets try to solve your problem. First, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and remove the water collection bucket and the air intake filter. Check the filter closely for significant dust and dirt buildup and clean it if necessary. Make sure the filter is thoroughly dry, before placing it in the unit. Leave the unit unplugged for at least 15 minutes or until the filter is dry. Then replace the filter, insert the bucket - making sure that it fits swaourely from top to bottom into the bucket holder. Plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, the 15 minute timeout has allowed the unit's electronics to reset themselves and they reverted back to the original factory settings. If so, set the controls to your liking and the unit should start and run like it should.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
My dehumidifier is two years old and only used during the summer months. This season it is running but not removing moisture from the air...the collection bucket is completely dry. Help!
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Empty the bucket and put back in, will not restart and light is on.
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
9helpful
Haier dehumidifier model de45ej-t What does code e2 mean? Unit does not run.
Top Haier Dehumidifiers Experts
ADMIN Andrew
ADMIN Andrew
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
