Air Purifiers Logo
Posted on Jun 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I forget and lost my puk code then what i do?
Anonymous
Level 3:
  • Master 6,831 Answers
  • Posted on Feb 15, 2011
Anonymous
Master
Level 3:
Answers
6831
Questions
0
Helped
1241418
Points
16135
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At the link below you will be directed to a tip i wrote on how to recover your PUK code.
Click HERE to navigate.
Kind regards
Lock123
What happens having one broken wire?
Not trying to be funny, but it depends on the wire, if your air purifier is still running or not, whether you have lost hi/low settings etc. Or is your plug wire and you lost the internal ground wire. Attached link you are able to download user manual. Need to be more detailed, color of wire, location of break. Hope this helps, or provide make model, and other details. PEACE
http://www.oreck.com/userguides/global-user-guide.html
Redirect Notice
I cannot locate my manual and I am trying to figure out how to remove limescale/calcium carbonate from the unit. My humidifier is not part of the vacuum cleaner it is the smaller one that you sit on the...
with a wet or dry old tooth brush. use a firm one though. you can also dip in a solution of CLR mixed with water,then wip it dry. dont forget to clean the spicket by turning it counter clockwise and using a q-tip or baby bottle nipple brush . do this under running water. good luck
It is making a lot of noise. I believe it is the fan and I have oiled significantly with silicone spray on both sides of the fan motor and it resulted oin only a small improvement.
you will need to remove and clean but as a last try use a good deggreaser to wash off , try and use WD40, the use light oil-SAE40 to the fan spindle points and check out.
It will improve a lot but repeat the process a few times ,then switch on and repeat.
If sucessful, dont forget to vote
My unit keeps turning off, attention required red ligth is blinking, I just clean te unit
make sure not to forget cleaning the corona wires. i used light grade sandpaper and gently cleaned the wires as well as scrubbed the metal grids with scotch brite pads. the unit has been running normally .
No air flow in my ionic breeze model S1853. Just the light is on.
The Ionic Breeze filters air from the room into the front vents and releases ozone through the back vents back into the air. Some models you can put your hand near the back of the machine and feel a slight breeze. If you do not feel any air or the light that is on is red, the magnetic plates that capture the dust, etc. needs to be cleaned. Don't forget to turn the entire unit, after removing the magnetic plates, upside down to clear anything trapped near the bottom.
Who is my soulmate??????????/
He/she is already married with children, and does not even know you exists. You will have to find a small puppy dog and love him/her, way less heart ache. Cheeper too. Also start going to a big Church lots of good people there, start a face book account and look for old school friends. Get out and go bowling, go to the grocery store and ask people how do you cook this,that. Take your new puppy for a walk in the park. Forget about a need for a soulmate and the ONE, will find you, when your puppy is not a puppy any more.
Ionic Breeze Table Top Purifier
Sharper Image has recalled the product line. They lost a lawsuit with Consumer Reports after they couldn't prove that they did clean the air. They were ordered to pay all legal fees forcing the company into chapter 11.
Consumer Products Safety Commission is going to issue a report on all ionizers by the end of the year. It's expected their decision will stop sales of all ionizers in the U.S. EPA data has already proven their use not only to be ineffective but harmful to use as well.
Car dieing
You may have a Vacuum Leak, Throttle Position Sensor may be bad, and the MAP Sensor. Those are know to go on the 3.1L Chevy Lumina's. Thank you for using Fix Ya! Don't forget to rate the overall rating of this answer. Good Luck.
Top Sharper Image Air Purifiers Experts
john h
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
