Dual Electronics Cellphone Dual Band Extender Logo
Posted on Jun 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to download java into phone - Dual Electronics Cellphone Dual Band Extender
Anonymous
Level 3:
President:
  • Master 1,285 Answers
  • Posted on Jun 20, 2010
Anonymous
Master
Level 3:
President:
Answers
1285
Questions
Helped
303065
Points
3126
Follow this link click on instructions
  • http://www.java.com/en/download/manual.jsp
to download java for mobile
follow this link
  • http://java.sun.com/javame/downloads/index.jsp
I don't know how to download .jar application on lg840g phone
if it is a java enable phone u will be able to download jar files otherwise download jad files
1helpful
When i download on ma phone, i get jar invalid command
The Invalid jar command is simply because you're downloading a java application not meant for your phone's version of the java software.
This is corrected by simply downloading Java applications meant for your phone, Thousands of which can be found at www.getjar.com
If you are absolutely sure that the Java applications you are downloading are designed for your specific device, You may have to try A) a master reset and/or B) upgrading the software/firmware of your device.
Hope that helps!
8helpful
3answers
How to install third party java apps on my SAMSUNG GT5233A mobile phone??????????????? Is it really possible??? then, how??????????????
you can only install and play java games by downloading the java games from internet directly from your mobile's default browser. you can't install java apps from memory card or pc. but please don't forget to rating my solution.
2helpful
I have a dual sim YPhone I68 and don't know how to install Java on it. Which Java app can I download on this phone and how? Can anyone help me? Thank you. Wher
I just figured this out myself...on your pc go to getjar.com. When it asks you what phone you have type in CECT and select the default phone. when you find the app you want select download n it'll give you a code. Go to services on your phone and select WAP. go to m.getjar.com. under platforms select JAVA. Scroll to the bottom of the screen and select quick download. input the code you got from the computers webpage and click download....then just follow the prompts. when you want to access what you downloaded go to JAVA in your phone. select Installed Java Software and it should be listed. (Note: this only works if you've set up internet on your phone.)
Pda i9 phone
To verify that the phone have Java installed already there should be a Java icon in the desktop. If there is any, then go to file manager and memory card, search for the saved games that was already installed in the phone and tap it, in a new pop up window you should be able to see "Install" tap it and after that just follow the instructions. Once the game is installed, tap the Java icon in the desktop to open the installed games. If there's no Java icon then it means that your phone have no Java in it.
4helpful
2answers
How to load apps on the ka08 mini phone
You have to download java apps for this phone & you also need a micro sd to store the apps. Brothersoft.com has tons of java apps, some work & some don't you just have to experiment. Once you download & save the file you just click the install link. You can then find the app under Java on the main menu.
2helpful
No java games compatible
you will need to download java games only you can download free java game on your phone at this site www.fastestmob.com on phone browser only
1helpful
2answers
Samsung SGH-D600 "Install error"
you need to reset your phone, that might solve the problem. a full master reset should work.
How do i download java applications to my phone
for that, u need to download the java games to your PC first.
after that connect to your PC through data cable or bluetooth.
start the samsung application loader software.
and rest u ll understand on your own.
thanks
1helpful
3answers
Java error
Hiya, this might help. Sometimes it can be a software problem. I downloaded loads of java stuff and my phone 'crashed' and the software needed updating which did the trick but lost me some of my java stuff. I found that my orange phone would not allow me to download orange java stuff and that I had to try an online company like mobilefun so it may be your tariff/provider or source of download that is the problem. Check what compatability you are downloading as not all games that were, will now be compatible as they often change to suit updated phones.
Top Dual Electronics Car Audio & Video Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Dual Electronics Car Audio and Video Expert? Answer questions, earn points and help others
