DEI Python 990 2-Way Security System/Remote Start with SST Technology Logo
Anonymous Posted on Jun 12, 2010
How do the reprogram python 990 replacement remote
Anonymous
Level 2:
New Friend:
  • Expert 74 Answers
  • Posted on Jun 15, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
74
Questions
0
Helped
28317
Points
148
Turn ignition on and within 10sec push the valet switch once then push and hold again. the siren will chirp once then push the lock button on the transmitter and the siren should beep once then let go of the valet switch and turn ignition off and remote should function properly
Testimonial: "Thanks!"
  • jshowell7875 Dec 12, 2010
    Worked perfectly.
    I'd studied the owners manual, a 60 page installation manual, and read several other posts/forums, etc. Your solution was simple, direct, and to the point.
    Excellent.
1 Related Answer
Anonymous
  • 5 Answers
  • Posted on Nov 17, 2008
SOURCE: reprogram python 990 remote
The P stands for programming. It's used when setting up the alarm system, you would need the manual for the system to tell you what can be done. I have a Python 990 and I can change pretty much everything from sensor adjustments, amount of time it turns over for starting, disabling the siren and many other settings. I found out the hard way one time when I accidentally pressed it and turned the key off and it disabled the siren. I think that's how it happened, been a while since it happened. I would have to get the manual out to be exact. You can also do the programming by pressing all 4 buttons at once and hold for 2 seconds. But you still need the manual to know what your doing. Hope this helps
Top Directed Electronics Vehicle Parts & Accessories Experts
john h
Arnie Burke
Arnie Burke
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
