Dell Dimension 4600 PC Desktop Logo
Posted on Jun 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My computer is Stack while i am working - Dell Dimension 4600 PC Desktop
Informat Enterprising
Level 2:
  • Expert 153 Answers
  • Posted on Jun 11, 2010
Expert
Level 2:
Answers
153
Questions
0
Helped
20313
Points
408
Bro this process can help you to arrange your fragmented disk space in order to prevent unwanted software application bugs and errors. follow this procedure bro> Run "Disk Cleanup button" in your Local Disk "Properties"; On the menu bar select "Tools", Click " Check Now" and click the two check boxes to fix and scan all the files inside the Local Disk; restart your pc then Go Back to Local disk properties+menu bar "Tools" and select "Defragment Now button", select the Local Drive; and if it is done to 100%. Good Luck and God bless.
1helpful
Cipher Lab 8200 When transferring data to the computer, it will be displayed error message time out.
Data transfer reaches **** could be a Stack Overflow, depending on the OS you are using and its configuration.
If it used to work, what has changed. Find out and reset it.
If it has never worked, get your C language memory working and rewrite the Stack Send level.
Is there any stack card which provides 2*QSFP+ optical ports can be used in switch S5720-56C-EI-48S-DC?
ES5D21VST000 is a stack card that provides two QSFP+ optical ports for stack connection, can be installed in the rear card slot of the S5720-C-EI and S5720-PC-EI series chassis.
1helpful
2answers
Does Huawei S5700-28P-LI-AC switch support stack function?
Of course, you still need a license after the switches are stacked, and the installation method is different from that of a stand-alone machine. You can refer to this document.
https://support.huawei.com/enterprise/en/doc/EDOC1100195305
16helpful
2answers
How to solve stack overflow line 207?
every time coming stack overflow at lin207
I have my plantronics discovery 975 paired to my computer and my phone. It is supposed to automatically connect when I skype and it doesn't. When it is connected it only lasts for less than a minute...
  1. Make sure you are using the latest version of Skype.
  2. Make sure that Bluetooth works on your computer. You can refer to your computer manufacturer's documentation or website for details on how to set up Bluetooth on your computer. You want to ensure that the Bluetooth software and drivers (known as the Bluetooth stack) on your computer supports the Headset Profile (HSP). It's recommended that you download and install the latest drivers for your Bluetooth stack.
  3. Pair your Bluetooth device with your computer. How you do this will depend on both the Bluetooth stack on your computer, and the Bluetooth device you are using.
  4. Make the Bluetooth device your Skype audio device:
  • Sign in to Skype and in the Tools menu, select Options...
  • Under Audio settings, select your Bluetooth device from the Microphone, Speakers and Ringing drop-down list.
  • Remember that not all Bluetooth headset features may be available when making a call with Skype. For example, whether the buttons on your headset function correctly depends on your Bluetooth stack.
Good luck from Headsets Direct!
1helpful
A message just "popped up"
It has to do with memory. When you make requests of your computer programs it puts those requests in a stack (or pile) and then works on them in a predefined order. There's a certain amount of memory reserved for the stack and when you exceed it you get a stack overflow error. These errors usually either kill the request or result in a program crash.
How do i set up bluetooth connectivity
If you have Windows XP with Service Pack 2 or 3 installed on the computer, then the computer has the Microsoft Bluetooth Protocol Stack. The Microsoft stack allows you to install an external Bluetooth adapter automatically. If the Bluetooth adapter supports the Microsoft stack but it does not install automatically, then you do not have the Microsoft stack on the computer.
>>Make sure that you have installed the HP All-in-One software on the computer.
>>Attach an HP Bluetooth adapter to the front USB port of the HP All-in-One.
>>If you are using an external Bluetooth adapter for the computer, make sure the computer is on and then attach the Bluetooth adapter to a USB port on the computer. If you have Windows XP with Service Pack 2 or 3 installed, the Bluetooth drivers are installed automatically. If you are prompted to select a Bluetooth profile, select HCRP.
On the Windows taskbar, click Start , and then click Printers and Faxes .
>>Double-click the Add Printer icon.
>>Click Next , and then select A Bluetooth Printer .
>>Follow the onscreen instructions to finish the installation.
>>Print as you would to any printer.
Regards
Riztech.
Stack errors with dlink 655,,disconnect, and no problem to connect to Internet...Re establish 655 and all computers get Stack errors with IE
You might need to download a hotfix from Microsoft for this Stack Error... Try visiting the link below
http://support.microsoft.com/kb/895194
Hope it helps!
Cd stack inside the drive imac aluminum 20
Hold down the mouse click when you boot the computer.
It will eject the cd automatically.
I know it sounds weird, but it works.
If not let me know, it's not the only way to do it.
1helpful
3answers
Kernel stack inpage error
i have recently experienced my computer is shutting down with a message kernel stack inpage error when i play a high graphics games or playing video files
is this fixable
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
