Microsoft Windows XP Professional SP2 Logo
Posted on Apr 07, 2010
Solution of error code 1002 - Microsoft Windows XP Professional SP2
Anonymous
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Apr 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
3183
Points
38
Click Start menu, and then click the Run icon.
In the small box that Opens, type the three letters: cmd then click the OK button.
In the command prompt window that just opened (a black background and white text), type the following commands, pressing the ENTER key on your keyboard afterwards:
regsvr32 msxml3.dll
Now type the word: exit and the window will close.
Now Reboot and try and Microsoft Windows Update again....
If it fails with the 0x8007007E error again try Step 2
Step 2) - Windows XP Only...
Now lets update your system with the latest Microsoft XML Parser (MSXML) version 3.0 SP4
Download Here (use the msxml3usa.msi for the English language version.)
Notes....
a) You will need to reinstall MSXML 3.0 SP4 if you upgraded to Windows XP from a computer running one of the following operating systems:
- Windows 98
- Windows ME
- Windows NT 4.0
b) Windows 2003 server
ships with version 3.0 - SP4 and so you do not need to install it.
c) Occasionally, setup may need to reboot the computer but fails to inform the user. Therefore reboot your machine just in case. Then try Windows Update again...
d) To install a localized (e.g. English) version of MSXML 3.0 SP4 on a system different from the previously installed version/locale (e.g. French) of MSXML 3.0 SP4, complete the following steps:
Unregister the existing installation package by executing the following command in a Command Prompt window:
msiexec /qn /x {45534579-B75B-4A42-953B-2EF8E1DEB4F3}
Now install the new localized version of MSXML 3.0 SP4.
If it fails with the 0x8007007E error again try Step 3
Step 3) - Windows XP Only...
Scan For Missing/Corrupt System Files...
Windows XP comes with a wonderful tool called System File Checker (SFC) It scans and verifies the versions of all protected system files after you restart your computer... However it can sometimes miss a problem, so we can run the tool now to replace CABINET.DLL and URLMON.DLL if there is a problem with them:
To Do This:
Click Start menu, and then click the Run icon. In the small box that Opens, type the three letters: cmd then click the OK button. In the command prompt window that just opened (a black background and white text), type the following command:
SFC /scannow
and then click OK
You must be logged on as a member of the Administrators group to run SFC..
You will need your Windows XP CD during this procedure if SFC needs to get an original file. Please remember that Windows XP can have multiple instances of a .DLL file and remember which version is for which program.
Notes....
I have been asked if it is possible to have a "progress meter" show when SFC runs... This is the registry hack you need. PLEASE do not go messing with your registry if you do NOT know what you are doing!
System Key: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
Value Name: SFCShowProgress
Data Type: REG_DWORD (DWORD Value)
Value Data: (0 = disabled, 1 = enabled)
IMPORTANT: This article will cure the 0x8007007E problem for many of you. However if it does NOT then I would love to here from you. Or, did YOU try something else that worked? Then email me the fix too!
You may also find these error codes useful - for future reference, especially when trying to figure out error messages in the Windows Update log! (They are only given here as a guide to general problems and will require further research on your part to resolve the particular problem you may be having.):
0x800C0002, 0x800401E4 and 0x80072EE5
The address of this site is not valid. Check the address and try again.
0x800C0003
Cannot start an Internet session.
0x800C0004 and 0x80072EFD
Cannot connect to the Internet server.
0x800C0005
Cannot locate the Internet server or proxy server.
0x800C0006 and 0x80072EFC
The site reports that the item you requested could not be found. (HTTP/1.0 404)
0x800C0007
The Internet site reports that a connection was established but the data is not available.
0x800C0008
Cannot download the information you requested.
0x800C0009
The item you requested requires proper authentication. (HTTP/1.0 401)
0x800C000A
The Internet site cannot return the object you requested. (HTTP/1.0 403)
0x800C000B and 0x80072EE2
The connection to this Internet site took longer than the allotted time.
0x800C000C
The site reports that the request is not valid.
0x800C000D and 0x80072EE8
The required Internet protocol is not installed on your computer, or the Internet address you requested may not be valid.
0x800C000E
A security problem has occurred.
0x800C000F and 0x800401EA
Cannot open the specified file.
0x800C0010
Cannot start the program needed to open this file.
0x800401E6 and 0x80040154
No program is registered to open this file.
0x80004004
The hyperlink cannot be followed to the destination.
0x801901F8
The transfer request timed out while waiting for a gateway. Resume the job at a later time. (HTTP Error 504)
0x801901F7
The service is temporarily overloaded and cannot process the request. Resume the job at a later time. (HTTP Error 503)
0x80190194
Error code:103-1002
Here's the solution to solve the problem.
1. Check your internet IP address. If the Wii-U is having trouble connecting try entering the IP address manually and the DNS manually.
2. Check the password to see if you entered it correctly. You may be using a T1 trunk Lindsey to security.
3.Finally check for outside interference, such as microwaves, smartphones, or other devices. If this still dosen't help, call Nintendo at 1800-255-3700 for assistance. Hope this helps.
Toshiba 720 error code 447
poor connection fuser drawer
go to this site to get error code listing
http://fyi.toshiba.com:81/KB/file_uploads/8535/TSB-1002.pdf
When i restore my iphone it stops at the end and says problem 1002
Okay so error 1002 is a baseband error. Either your baseband software is bad and you need to flash to the newest version, or the baseband hardware is shot. If your hardware is shot, guess you need a new logic board etc. But as I just researched some more on that issue I did find that Sn0wbreeze 2.5.1 will bring a fix to iTunes "error 1002 & 37 which was mainly experienced by iPhone 3GS users while restoring iOS 4.3.1 custom IPSW coupled with iPad baseband 06.15.00." Anyhow, might be worth a try, not much to loose I suppose. If you are looking to download it or to get more info, it is here. Good Luck to everyone.
Hp error code for compaq presario code 1002
http://h30434.www3.hp.com/t5/Operating-systems-and-software/Recovery-Error-Code-1002/m-p/11366
2helpful
Error 0x400 100 130000 1002 is showing and I can't even open the pc
Error 0x400 100130000 1002
This issue persists if the hard drive has bad sectors.
Run a Hard drive test in BIOS and check if you receive 'Read Failure' it is shows hard drive is defective.
6helpful
3answers
Durabrand dvd player code
Here is the code for the dvd player
0449, 0405, 0446
code for the tv/dvd combo
0189, 0135, 0157, 0153, 0254, 0458, 0217.
website to find the other codes if you need.
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
have a good day walmart shoppers.
Top Microsoft Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
