Fujitsu LifeBook T4215 Tablet PC Logo
Posted on Mar 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot connect through the internet. - Fujitsu LifeBook T4215 Tablet PC
Anonymous
Level 2:
New Friend:
  • Expert 121 Answers
  • Posted on Mar 21, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
121
Questions
0
Helped
25274
Points
241
Get a network cable and connect it to the pc and then conect gthe other end to your internet router/modem
I can not connect to the internet with my zeepad. I bought both of my daughters the same model tablet and they can get on the internet with their tablets.
Most tablets connect to the internet through WIFI. Only a few can use SIM card to connect through 3G or 4G data connection. For WIFI connection, you must have a WIFI router at home. You will normally password-protect the WIFI rounter. To connect the tablet to the internet through the WIFI-router that is in operation, you will configure its WIFI settings to match the router's password. This will be done by going to tablet's Setting, turn on WIFI, click on your router in the list of detected routers, enter the password when prompted. Ensure that Connected is shown against your router. You can then browse the internet.
How do I get it on my wifi network? it keeps telling me it is avoiding the network because of poor internet cinnection.
If you have poor internet connection problem with your WiFi, try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from ScanmySpeed.com before and after following these steps.
Tablet won't let me open anything. Bought from a garage sale and she reset it and now it won't work. I tried opening google play and it still wouldn't connect
Because you keep getting "an internet connection error" it sounds like it is not connected to the internet. I would try to address that problem first. I would go in and delete the wifi connection and re-add it using the correct network name and passphrase for your wireless access point. I think that once you get the internet connection error to go away, you will have better results with internet-dependent functions like the app store. Also make sure you don't have airplane mode or other feature activated that would turn off the wifi.
If my computer does not have internet can i still connect to netflix
Can your computer connect to the internet? If it can, it just means that you have a wired internet connection and not a wifi connection on the computer, which means your iPad is just connected to your home network via wifi. If your computer can't access the internet or you know you don't have internet service at home, then you either have cellular service (3G/4G) or your iPad is connected to some other available WiFi from someone else's service.
No internet connection
You can contact your Internet Service Provider and get the internet connection.If you need to check your internet speed visit the site Scanmyspeed.com .
Wifi connecting
When creating a connection to internet, you need a point (read : router) which facilitates this. If you don't have a router in your neighbourhood, you can't connect to the internet. Even if there is one near you, you must be able to see it, by checking at your tablet for wireless connections. However, some routers are set to accept only connections, when a user ( your tablet) can provide this password everytime it tries to connect to the internet.
Schematic of internetconnection :
Tablet --- WiFi Router --- Modem --- Internet(provider).
1helpful
1helpful
How to I install the internet to my cobyMID7016? I had it working at one point, but now it will not load to my coby?
http://www.cobyusa.com/?p=faq#faqcat_8
on this page you will find almost all answers for your questions related with the tablet ..(under internet tablets sector )
The issue in your case it is the internet connection itself ..either the wireless network you used it is not working anymore or not on (if you use a router ) ..or simply you reset the tablet and you need to make the connection again ..Just open the internet connections ..(wireless card 0 ..and select to scan for networks ...and when you find your network ..select ti ..and than click connect ..This should connect it right the way ..
Also check if your internet network may need your mac address for to let you connect ..(this happens on the networks having the access restricted by the Mac address..)
to get it follow these :
  1. Click on Settings.
  2. Click on Wireless & Networks.
  3. Click on Wi-Fi Settings.
  4. Click the MENU button, located on the side of the unit.
  5. Click on "Advanced".
  6. Your MAC address will appear in the Advance Menu ..
same way to get to the connection for to activate just open wifi connections ..
My Toshiba r15-s822 isn't connecting to a wireless network and the router I already installed the router to my pc even connected an internet cable to it but Internet Explorer wont open it keeps...
Try connecting to the Internet through the ethernet port (via a cable). If Internet Explorer loads the target page then you have a configuration problem with WI-Fi access : The wireless security settings are not allowing the computer to access the Internet.
If Internet Explorer does not connect with the cable then the problem resides with Internet Explorer. Try to reset the defaults. To confirm that download FireFox and use it. Besides you need two browsers just in case one acts up.
I cant connect to internet but i installed the necessary driver
To connect to the Internet you need a few extra things aswell as a network card.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet. If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Top Fujitsu Tablets & eReaders Experts
Anonymous
Level 1 Expert
Anonymous
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
