SOURCE: INSTALLING JAVA GAMES ON SGH-L760
Great news guys...i manage to
install games from my computer...using the cable...got the following
instructions from a forum...bit tedious but its better than nothing
right?
http://www.zedge.net/forum/t/37784/g...700-it-goes/1/
it goes something like this...
"First you need the “Qualcomm USB” drivers and “BitPim”. Prepare the USB cable, but dont put it in!
Driver: www.rexnet.it/firmware/utility/qualcomm_usb_driver.zip (changed from the original coz it didnt work for me)
BitPim: http://sourceforge.net/projects/bitpim
a. Unpack the drivers to a folder (exp. Desktop), but don’t install it!
b. Install BitPim.
1. You must entering follow code into the phone: *#0523#
2. [9] common >> [6] USB Configuration >> [2] Qualcomm USB [*]
--> Qualcomm USB Configured.
Plz Reconnect the Cable.0
3. Now put the USB cable in the phone and Pc.
--> Windows found a new hardware.
Install the hardware manual and chose the Qualcommdriver folder.
Now go to the Hardware manger ->Modems->Qualcomm, you must know the port number.
4. Open “BitPim” and configure the software for your u700.
Phone type: Other CDMA phone
Com port: *look at step 5*(you can Browse, but chose the right one!)
And press “OK”
5. Start “BitPim”, go to the menu “View” and active “View Filesystem”.
6. Klick on “Filesystem” (left in BitPim).
Now can you see a blue folder, open the folder (press on “+”).
--> … retrieving
7. Now put the games (jar and jad files) in the follow folder “Games” (Media->Games).
8. Disconnect the USB cable from the phone.
9. Leave the Qualcomm menu and entering this code in your L760: *#6984125*#
Now are you in “Admin setting” menu.
a. Select the menu [4] Internals (Master Key: *#9072641*#)
b. Chose the menu [7] Storage settings
c. Update media database, Update Java DB and Create AX Dat File.
That it’s!! (You can leave “Admin setting”.)
Important: DON’T delete the games with the mobile phone, you must delete the games with “BitPim”.
SOURCE: I want to install java applications in my Samsung
Try install application via Samsung PC Studio.
SOURCE: How to install java games (.jar , .jad files
hi, you have to coppy the jar file into the install folder on your phone and make sure the java version of your phone is compatible with java file. then install from the folder.
SOURCE: lo i have Samsun champ
hi frnd please select jar file with only upto 200 kb find it on www.mobiles24.com
