SOURCE: when vewing tv sometime a box pops up saying not available in current mode
try changing the hdmi cable to hdmi1 slot, also try with component cables, since they are HD also. also check to see if tv is in air or cable status
SOURCE: Black Screen
I have a Samsung HP5053 Plasma Flat Screen and there was a cracking noise and the picture clarity changed to dull. Does anyone else have information on recalls for this TV?
SOURCE: samsung lcd 720 ln32b360 doesn't fill screen in
If by regular cables you are talking about the standard red/yellow/white composite cables, then, yes, it will affect HD as composite cannot send an HD signal. Only HDMI and component (red/blue/green video only) cables.
Change to HDMI and let us know if it works for you.
SOURCE: vizio P50HDTV 10A, Replaced power
It might have got a smallpoer surge and if you unpulg the set fromthe wall that should rest everthing back to normal, also check the inpu voltage going to PIP module.
