Microsoft Xbox 360 Console Logo
Posted on Dec 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E68 Error Please Help - Microsoft Xbox 360 Console
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Feb 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
170342
Points
31
Turn off system, take hard drive off, put hard drive back on, turn system back on.
Anonymous
Level 2:
New Friend:
  • Expert 58 Answers
  • Posted on Dec 18, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
58
Questions
0
Helped
11500
Points
154
Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it. this might be caused by a problem with the fans as well.
if this doesnt fix your problem 1800 4 my xbox will help you get your system sent into them to fix it for you.
2answers
What is an error code e-68 on a galaxy series dryer mean
E68 error code is a stuck button error code. You can try to wiggle each button on the control panel to make sure they are all functioning freely. If so, then unplug the dryer and leave it unplugged a couple minutes then plug the dryer back in to clear the electronic panel's error code. If the panel still shoes E68, then you'll need to replace the panel. Part#134557201
Hope this helps!!
Jun 13, 2016 • Dryers
Error code e68
Good Afternoon Friend,
I understand you are receiving an E68 error code on your Frigidaire Affinity washer, model# ATF7000E. The E68 error code states that there is a possibility something is going on with the heating element inside your washer. It could also be a false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start your washer on the hottest cycle on a heavy soil level. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
1helpful
Frigidaire affinity XD71702132 error 68
Please click the link below to see my answer to a similar E68 question on fixya:
https://www.fixya.com/support/t10225683-error_code_e68_frigidaire_affinity
Was receiving E68 code on Frigidaire GLEQ2152ES1, replaced circuit board and am still receiving the e68 error code. What else will cause this error?
Hi yoyosam66...
Your e68 error code means:
Please take time to rate me
E68 - Push button does not function
Cause:
Push button held too long or wedged in the control panel. Solution:
Press buttons lightly and release.
Disengage button.
1helpful
E68
The e68 error can mean a bunch of different things on an Xbox 360.
I have personally had this error and I had to turn the unit off, unplug it, disconnect the HDD, reconnect the HDD, plug it back in and power it on.
Fixed it like a champ.
Here's some useful websites that contain information on the e68 error:
http://www.ehow.com/how_5121542_fix-xbox-error.html
Thanks and please rate if this helps you!
What is e68 on a xbox
What you need to do is
1. rmeove the hard drive from unit then turn it on
Foolwo this link and what is is and how to fix the issue
http://ezinearticles.com/?Xbox-Error-E68---Xbox-360-E68-Error-Repair-Tips&id=2340222
thanks and hope this information does help please do leave your feedback and ratings.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Got system error E68-and a red light-this has happened after using a hard drive to save my game data-now can't find any data-would appreciate assistance!!!
I've got a permanent fix for Error E68 to help you out, But first ill tell you my XBox was dropped so it might have just worked for mine, i will be posting a vid on youtube by Nov. 5 2009 look for imthatstupidkid fix X Box Error E68 walkthrough
4helpful
2answers
PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
11helpful
Dryer keeps stopping error code e68
E68 error refers to "Current leakage to ground on heater or fuse opened".Problem with the fuse.Try getting it replaced.This can be done by any local repairman.Need not be a technician from Frigidaire,as they charge a lot for servicing. Good luck with the machine.Please do post results and comments.
11helpful
ERROR MESSAGE E 68
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Narseman
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
