This article might help you in fixing the error code 19. I have tested
this one and it worked for me. The error means that the optical driver
got corrupted.
Microsoft Windows Vista
loadTOCNode(2, 'resolution');
Microsoft Windows XP
, and then click All Programs.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters
only. If you do not see the UpperFilters registry entry, you still
might have to remove the LowerFilters registry entry. To do this, go to
step 8.
Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
step 7.
Device manager error code 19, is caused by registry error
windows cant start the hardware due to this error
you can uninstall the driver to cure this and download from this link new driver if windows does not reinstall, check device manager (normally cd/dvd drive i think)
http://gd.panam.acer.com/home/
open device manager uninstall the driver
START> (Right click) my computer select manage> in computer management window that opens in the left pane you will see Device manager click that and all devices will appear in the right pane>extend the path of required device
you will see a yellow triangle, right click required device in extended path and select uninstall
now click action (top left in window) and select scan for hardware changes, if windows cannot locate the driver use the link
