Computers & Internet Logo
Posted on Oct 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jscript error = "cannot compile" - Computers & Internet
Anonymous
Level 2:
  • Expert 73 Answers
  • Posted on Dec 08, 2009
Anonymous
Expert
Level 2:
Answers
73
Questions
Helped
18750
Points
122
U probably have a syntax error in ur js file
1helpful
3answers
Compile error in hidden module
https://www.wordrepairtoolbox.com/
Microsoft Word repair software is more efficient than some other methods of data restoration, including regular backups, just download this application on your computer and start recovering, the ease of recovery toolbox Microsoft Word document repair tool permits starting the analysis without some kind of additional explanations.
Error code 0x80070422
That code seems to be used in a number of MS software products. The closest I can find is "Duncan McAlynn Microsoft System Center Compiler returned error 0x8007042c Error Code: -2147217406 (IDispatch error #3586)"
Try this forum
http://msmvps.com/blogs/lduncan/pages/20217.aspx
1helpful
Linker error:Unable to open file 'TCLASSS.LIB'
this is the basic lib class required by the compiler make sure your libs variable to pointing to the correct location the the libraries required by the compiler.
2answers
Compile error in hidden module: picMain
You haven't provided much information here, but here is a Microsoft Knowledge Base entry that may assist you.
http://support.microsoft.com/kb/307410
I'm trying to download a script that i had but uninstalled. the error message i get is as follows: C:\Users\Chuck\Downloads\powertoolsthefamily.user-50.js line: 76 Char: 1 Error: Expected identifier,...
Hi chuck_16!
Thank you for using fixya!
If you are using IE for downloading this script you may try using firefox instead.
Download firefox from mozilla.com
Install
then access your download from there.
Thanks,
avf110686
Can you give an example of compiler using vb?
Dim parameters As New CompilerParameters() Dim results As CompilerResults parameters.GenerateExecutable = True parameters.OutputAssembly = Output results = icc.CompileAssemblyFromSource(parameters, SourceText)
The code above uses the CompilerParameters object to tell the compiler that you want to generate an executable file (as opposed to a DLL) and that you want to output the resulting assembly to disk. The call to CompileAssemblyFromSource is where your assembly gets compiled. This method takes your parameters object and the source code, which is a string. Once you compile your code you can check to see if there were any compilation errors. We use the return value from CompileAssemblyFromSource, which is a CompilerResults object. This object contains an errors collection, which contains any errors that occurred during the compile.
There are other options for compiling, such as compiling from a file. You can also batch compile, which means you can compile multiple files or sources at the same time. Additional information on these classes is available on MSDN Online:
Please help
cant open my aol mails
Error occur during compiling,unable to open a header file
The compiler is attempting to access the iostream header file and it either cannot find the file (not in the default location or it has been told to look in another location where it doesn't exist), or the file security is set so the current user does not have read access to the file.
Uhm, i just downloaded the adobe photoshop program and it says setup has encountered an error and cannot continue please contact adobe coustomer support for assistance. internal error 2739. so can you...
Hi-
Try this
Open a command prompt, navigate to C:\Windows\system32 and type in regsvr32 jscript.dll and press ENTER
c:\windows\system32\ type regsvr32 ***remember to put one space and then type*** jscript.dll ,,
c:\windows\system32\regsvr32 jscript.dll (( like this or it will not work))
If all fails call Adobe Installation Support number: 800-642-3623.
Thanks for using fixya, pls rate solution if it helps.
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
