Check if java script enabled in your browser.To check this go to IE -tools- options-there security tab click custom level button and enable scripting option.
Hello. The steps below works for me. I've tried it soo many times in different Computers and laptops.
You just need to turn off the Javascript of your browser. Login to your yahoo mail then Follow these steps
1- If your browser is firefox do the following 2- Open TOOLS -> OPTIONS -> CONTENT, click on "DISABLE JAVASCRIPT". 3 - press F5 or reload your browser screen 4 - Follow one step instruction on your screen 5 - After that Enable the Javascript again. By going to Step 2
1- If your browser is Internet Explorer do the following 2- Open TOOLS > INTERNET OPTIONS >> SECURITY. In security click "CUSTOM LEVEL" -> disable active scripting in the scripting section. 3- press F5 or reload your browser screen 4- Follow one step instruction on your screen 5 - After that Enable the Javascript again. By going to Step 2
1 - If your browser is Safari 2 - Open SETTINGS>click PREFERENCES>>click SECURITY>>Uncheck ENABLE JAVA and ENABLE JAVASCRIPT 3 - press F5 or Reloard your browser screen 4- Follow one step instruction on your screen 5 - After that Enable the Javascript again. By going to Step 2
Please the following solution as its working on me. You just need to turn off the Javascript of your browser. Login to your yahoo mail then Follow these steps
i've tried this on different computers and it is working. I hope it will work with you.
You have not mentioned your web browser. ANyway try this as it works for me.
javascript:void(0) is an error message that occasionally appears in a web browser when there is a problem loading a JavaScript from a web page.
Here are some Possible Resolutions you can try:
Disable your popup blocker
Disable your web proxy, if you have any.
Enable JavaScript
Switch web browsers or upgrade your web browser
It is also possible that the website you are viewing has nn improperly written JavaScript. There's no way we can resolve that on our end.
Navigate to a site that uses Javascript applications. You may see the error message informing you that Java is not enabled, and the website components won't work properly.
Go to "Options," "General," then "Java/ECMA Script."
Choose "Enable" to activate Javascript.
Refresh the web page. If the Java elements of the page work, then you have been able to activate Javascript on your phone. Otherwise, troubleshoot the problem by turning the phone off and on, or checking for any web browser software updates. You may also want to check another Java based webpage to ensure that the problem is not with the page you are trying to access.
for mozilla
Select Preferences from the Edit menu.
Click the arrow next to Advanced.
Click Scripts & Plugins.
Check Navigator beneath "Enable Javascript for".
Click OK.
Click Reload
for firefox
Select Options from the Tools menu.
Click the Web Features icon.
Check "Enable JavaScript".
Click OK.
Click Reload.
post the javascript code and I will have a go at seeing why it is not working - it may be that IE 7 needs slightly different code but when I see or get the code you have I can look into it more
