Error code E74 happens because the display chip has overheated to fix it all you need to do is stop the heat build up, you can do this yourself or you can send it back and Microsoft will do it.
If you are going to do it yourself you need a good Xbox 360 Repair guide
SOURCE: error e74 on xbox 360
open it up and start putting random washers in this is what i did when bottom right hand corner showed up red with an E 74 error now it has been working fine for a year and a half
SOURCE: how do i fix my xbox 360 e74 error code
you can fix e74 wiht te same process as the 3 red light problem
SOURCE: Xbox 360 error code E74
E74 is a graphic chip error. Best bet is to sell the system because the fixes dont last long.
nickelci @ snet.net for more info.
SOURCE: Xbox 360 E74 - Need To Get Fixed
http://forums.xbox-scene.com/index.php?showtopic=484726
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement
SOURCE: E74 error code Xbox 360
chip near the AV cable connection).
It could also be caused by a faulty AV
and may be repairable by doing the x-clamp replacement. If your warrenty is still on, ask the store you bought it from about the error.
does it descride why error occured. did it happen when u put in a disc or treyd playin a cretain music file
