Dryers Logo
Kathy Peniuk Posted on Jul 06, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a TS code. Thermistor is good. We clear the code as per instructions above. Dryer will work for less than a minute then TS5 code again. When in service mode it shows 1 when I rotate the dial. Could this be a contro board issue?
  • Kathy Peniuk Jul 06, 2020
    We are also going to check if the vent system is restricted. Code 1 says in the manual that might be the issue.
Level 3:
  • Dryers Master 6,751 Answers
  • Posted on Jul 07, 2020
Cindy  Wells
Dryers Master
Level 3:
Answers
6751
Questions
0
Helped
3613921
Points
21938
I've seen this code when the exhaust cover can't move freely. When you check the vent, make sure that the cover moves easily when you are done. Also check for accidental constrictions if you use a flexible exhaust pipe.
If there is no blockage or restriction, then check the wiring between the thermistor and the control board. If the wiring is undamaged, then the control board certainly could be faulty. (Check the wiring harness and the contacts at the control board. A little corrosion could be a factor.)
I hope this helps.
  • 1 more comment
  • Kathy Peniuk Jul 07, 2020
    Thank u Cindy. All looks good. I am afraid we have a faulty control board. Maytag repair guy is coming Friday. Is a control board worth replacing or are u better off to just buy a new dryer?
  • robert Jul 07, 2020
    There is more than one thermistor
  • Cindy Wells Jul 07, 2020
    What model dryer is it? How old is it? If it is under warranty, then the repair always makes sense. In general, the control board is the most expensive electronic part of the dryer. Just for an example: the control board for the MDE9700AYW is $353 athttps://www.partselect.com/Models/MDE970... .
5 Related Answers
Anonymous
  • 11 Answers
  • Posted on Apr 20, 2009
SOURCE: Diagnostics on Kenmore Elite Dryer
my dryer just did the same thing i wiggled the door switch and it came back on
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on May 20, 2009
SOURCE: Frigidaire Dryer only runs on "low Heat" setting
Mexitronics
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Anonymous
  • Posted on Feb 27, 2010
SOURCE: maytag neptune MDE9700AYW ts t5 error
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Hope this helps
Anonymous
  • 15935 Answers
  • Posted on Sep 29, 2010
SOURCE: Maytag Bravos Steam dryer that reads service error code F1
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
http://media.fotki.com/1_p,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Anonymous
  • Posted on Jul 06, 2012
SOURCE: Maytag Neptune Dryer MDE5500AYW beeping and resetting itself
our maytag neptune dryer control board keeps beeping and flipping into all its options the top and bottom dryer do i reset the computer? we've unplugged it but it continues
Top Dryers Experts
AskDyson
AskDyson
ADMIN Andrew
ADMIN Andrew
