Computers & Internet Logo
Angie Posted on May 08, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ECC code how to fix - Computers & Internet
Attique-ur-Rehman
Level 3:
Top Expert:
  • Computers & ... Master 2,677 Answers
  • Posted on May 08, 2020
Attique-ur-Rehman
Level 3:
Top Expert:
Answers
2677
Questions
Helped
922827
Points
8011
Fix ECC Error Hard Drive
Try running the sector verification utility particularly of your hard drive manufacturer, which will help in examining each of the sectors and then relocate the bad ones (this way removing those from the sector pool that is available)..
https://www.systools.in/blog/fix-ecc-error-hard-drive/
The ECC number is a registration number, issued to all the Central Excise Assessees. This Number is based on the principles of 'Common Business Identifier' which shall be used for revenue accounting, validation of documents (e.g. CENVAT invoices), inter-agency coordination and for creation of data warehouse.https://www.tallyeducation.com/website/CHM/TallyERP9/Excise_for_Manufacturers/Excise_Control_Code_ECC_No.htm
My New A.O. Smith water heater is showing an ECC code what can I do
Hello, Frazell -
If your A. O. Smith water heater is new, it probably came with an owner's manual. Find where you put yours and check the manual to find out what the ECC code means.
From an owner's manual for a particular A. O. Smith Hybrid Heat Pump Water Heater, the code ECC means the heat pump compressor is not functioning.
Source:
https://www.manualslib.com/manual/755258/A-O-Smith-Hybrid-Electricheat-Pump-Water-Heater.html?page=17#manual
Best wishes.
1helpful
2answers
Will a Samsung 256MB DDR PC2700 CL2.5 184 PIN work
No that memory is not compatible. The Precision 350 uses memory called RDRAM aka RAMBUS.
Here are the speeds and sizes that are supported.
Memory modules supported PC800-40: 64-, 128-, 256-, 512-MB, non-ECC or ECC
PC1066-32P: 128-, 256-, 512-MB, ECC and 64-, 128-
,256-,512-MB, non-ECC
Minimum memory PC800-40: 128 MB non-ECC and ECC
PC1066-32P: 128 MB non-ECC and 256 MB ECC
Maximum memory PC800-40: 2 GB non-ECC and ECC
PC1066-32P: 1.5 GB non-ECC and ECC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/benjamin_29adbb94bfb43281
Dell Precision 530 with dual Xeon CPUs. Uses Rambus memory. (4) 256mb ECC modules are installed. It should be a total of 1 gb. However, BIOS only shows 256mb total even though it shows all 4 rambus...
It sounds like like you have multiple issues. When all memory slots are filled with 256 sticks the computer boots but only sees 256 MB instead of 1 gig.
When you install the Crimms it won't boot at all.
You may have an open circuit on one of the Crimms.
As for the computer seeing only 256 MB you may have a bad memory slot on the motherboard.
Here's a link regarding Direct Rambus DRAM or DRDRAM (sometimes just called Rambus DRAM or RDRAM: http://en.wikipedia.org/wiki/RDRAM
An error code jfb0 Bus Eror - Data Parity Error Detected Parity Error The system is a Sun Blade 2000 What can I do to fix this
replace or remove whatever ram chip is faulty, that error refers to a crc check on ecc memory. Or you could just turn off ecc parity checking in the bios. But that simply defeats the object of having ecc memory in the first place
Can the bios support using ecc memory to run as non ecc?
hi simple answer no, this feature is designed for that specific reason, if you have ECC ram you have to enable the ECC support in the bios, ECC ram has a different timing and ways of using the data flow, it is much slower than non ECC ram and uses more voltage, that's why most people prefer normal SD ram or DDR ram, you can however use these in *********** board if you turn the ECC support off, so long as your board will take the specific ram....hope this helps
Dislpay is blank but oven works
HI, you will need to replace this faulty ECC. the chip set that is soldered on this board is damaged as well as the led display. replacing the Electronic Clock Control will fix this issue.
the control board is fine and this explains why the oven is still functional. its the ECC that is faulty.
Click here to purchase your new ECC online.
VOLVO 850 ECC SYSTEM JUST WANT SOME FEEDBACK
YES I FIXED IT IT WAS THE THE POWER STAGE UNIT THIS ECC SYSTEM HAS 20 PAGESOF ALL KINDS OF VOLTAGE TESTS AND YOU MUST HAVE KNOWLEDGE OF THE COMPLETE SYSTEM AND WHAT TIS POWER STAGE UNIT DOES IS NOT LET THE ECC RELAYS GET TOO HOT AND SYSTEM SHUTS DOWN AND YOU MUST RUN ALL KINDS OF VOLTAGE TESTS TO PROPERLY FIX THE CLIMATE CONTROL SYSTEM AND HAVE ALL I MEAN ALL THE DIAGNOSTIC DATA ON THIS SYSTEM
2answers
Tried to upgrade RAM now computer won't boot up
check ther is 4 ram bank and if then fix ram after left 1 bank.then check .
there is also check frequency same of both ram.
2answers
Ecc
ecc RAM are better RAM install it
RDRAM
If you mix ECC and Non-ECC, the system will default to treating all the .... ECC vs Non-ECC there is no harm in doing this but if there is any old ecc the system will run all as ecc
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
