Nokia 3110 Cellular Phone Logo
Anonymous Posted on Sep 13, 2009
Security code securitycode nokia 3110c security code
Anonymous
Level 3:
  • Master 365 Answers
  • Posted on Sep 13, 2009
Anonymous
Master
Level 3:
Answers
365
Questions
Helped
112988
Points
1004
Try the codes
12345
1234
00000
0000
11helpful
3answers
I have forgot my securitycode for my mobile nokia 3110c
try 1234,12345 or 0000
if they dont work. call nokia they'll tell you what to do exactly
OR try this first
At the standby screen type the code:
*#7370#
or hold down the following 3 buttons when you first switch the handset on:
[Green, pick up call] + [3, def] + [*+]
Be warned this will delete all information on the handset and return the handset to a 'fresh out of the box' state. All contacts, installed applications, calender entries etc will be lost.
If you want a soft reset then there is another code:
*#7780#
This code will rewrite a few system files but doesn't peform a full format like the other two codes above.
*EDIT* Make sure you have a full battery when reformatting a phone.
10helpful
5answers
I forget my nokia 5233 security code.so tell me how to i open it or reset .
Std Nokia factory setting or security code is 12345, but if you change already, only flash box will solve your problem. I'm not sure is there got online solution for unlock if lock code changed by you.
Nokia 3110c how to format
Inorder to format your set,you can use following tips; FOR HIGHER ORDER PHONES(LIKE N,X,E series..): Dial *#7370# then your phone will ask a securitycode,there you can type your code.then it wil format and restart.
FOR OTHER MULTIMEDIA NOKIA PHONES: Here you can't format yourphone,but you can reset it; For that,go to;SETTINGS-RESTORE FACTORY SETTINGS- AFTER CLICKING IT, your phone will ask a securitycode there you can type your code.then it wil format and restart. "IF YOU THINK MY SOLUTION IS HELP FULL TO YOU,THEN DON'T FORGET TO RATE ME"....THANK'S
I have forgot my securitycode for my mobile nokia 3110c ..IMEI is 353081020389378
you could try generating a master code using this web site. it is free. but if that code doesn't work, then your phone must be physically connected to a computer and using some special tools and hardware, extract the code from the phone.
7helpful
2answers
Nokia 3110c mobile, i forgot security code.now how
Sir i have Nokia 3110c mobile, i forgot security code.now how to reset security code?
4helpful
2answers
Nokia3110cunlocking
HI, You have to type in security code of your phone in order to log into the phone.... By default the security code is 12345 and if you have changed it, you must be knowing.... BUT IF YOU WERE NOT ABLE TO GET INTO THE MOBILE WITH THE 12345 OR IF YOU FORGET THE SECURITYCODE, the one and the only way is to flash the mobile phone(ie, reinstalling the firmware), this cant be done by the normal person, u have to take the phone to nearest service center and flash it, they may charge u very minimal amount......
CAUTION: You may loose all the content stored in the phone memory, be careful,but no other way than doing this
Security brack
how to brack my nokia 3110c security codea 3110c security code
2answers
4helpful
5answers
i forgot my security code of nokia model 3110c. my mobiles imei no: 353081029988329
Top Nokia Cell Phones Experts
Kolbrun...
Sudeep Chatterjee
Sudeep Chatterjee
Rommel Balcita
