Its almost 4days I've recieved an SMS that BLocked my SMS box,I can't
read,sending Neither and I'd apreciate your help
thanks indeed
I found this solution posted as comment on this clip:
This following solution was suggested on youtube, it worked for me. There is one negative point about it: ALL YOUR OLD MESSAGES WILL BE DELETED
If you delete your sms.db file (located in: var\mobile\library\sms) it fixes it, you can open and send\recieve sms. i think the only permanent solution is to upgrade to 1.1.3 with itunes and start again (im asuming u got the bug using ziphone, i did). i installed isms as a backup sms service incase it stops working, which it does often. you cant look at recieved messages, but good for sending sms if sms.ap is playing up
to delete sms.db i use mobilefinder on my iphone
Help!
My new iPhone gets SMS messages from other AT&T users but is not getting SMS messages from non-AT&T users - anyone have this roblem? Suggestions?
I just can not send SMS from my phone
Ok
now send a message to your number from a random no. from which you usually dont receieve messages.
now click on reply.
the window will open and close.
now again click on messages.
DELETE THE NUMBER FROM THAT INBOX WHICH IS FULL OF MESSAGES.
now click back.
open the sms it ll work.
its because CURRENT MESSAGES THAT YOU WERE TYPING WERE VERY LONG, and TOOK ALL THE RAM MEMORY.
keep up.
i did it myself.
IPHONE ROCKS :).
Hi
even i face the same problem a month ago i formatted my cell fone and agin connected it to the PC n took the back up from itune it reconfigured it to the last settings of mine.
But one thing u have to make sure is that once u get something like that please dont attach it to your system else your backup will also get screwed.
I hope this will work for u
anything else u can get back to me on grarathi@gmail.com
SO here is the guaranted solution of SMS issue, even I faced the similar kind of issue : When u press on the Sms, it will just open and close again. So all u can do is goto Setting->General->Reset->click on Erase all content and setting.
Once u reset u can see no data in ur iphone, when u connect to ur computer that has itunes, it prompt two option:
option 1: ask for connect as new phone
option 2: or backup the previous data.
Select option 1.
Then u can find ur iphone perfectly working fine. Only thg is u tend to lose all ur previous contact, So make sure u note all ur contacts before u perform this operation.
And gr8 thg is I am using unlocked apple iphone with BSNL service provider. CHEERS..:)
I want to block someone sms from my iphone. How to do the block sms function? Pls help
Find your solution from the list,
Apple Iphone Smartphone
Codes:
Software & Hardware Problems
Find Your Solutions for Apple Products:
Apple Iphone 3G
Apple iPod Touch Digital Media Player
My Phone is a Iphone Clone 32GB and its driving me Nuts! The phone indicates me that Ive received missed calls and SMS's but when I try to look them up, i can't find that darned SMS or missed call. I also want to know if i can download a new and easier software to the phone. And if its possible whats the best software?? Pleas someone help me as quick as possible. :C
My iphone is now at 1.1.3. When my sms box is filled with sms. When i press the SMS to start up, phone would either just Hang or SMS will not start. Same thing will happen when I recieve an sms.
My iphone has currently more than 2000 contacts. The issue above only starts to kick in when all my contacts are updated into the phoen. Previously on 1.1.1 no issue.
Any one experienced this or has a solution? My guess is the the new SMS program was not properly written to take care of this issue.
I'm not sure about that...I know you can call the at&t store and ask for assistance
Thanks. Extreme but it worked
With 1.1.4 fw my iphone was working fine, till recently i noticed that some of the touch points in the lower portion of the screen will NOT function when trying to sms eg the space bar or the numeric change button. Plz help
RC
Thanx after i delete the sms.db its working soo good but what about the phone icon it has the same problem
hi .. even i have having the same problem..
I AM NOT ABLE TO RECD SMS OR SEND.......
Are there other solutions for this? It happened twice now to my iphone! Whenever I press on the Sms, it will just open and close again. I can't read any messages nor send. The first time it happened I had to restore all settings. Will this problem persist? What's causing it?
I've restored phone setting, twice. Still, I can't read, write, view old sms. HELP!!!
recieved a sms that caused my iphone's sms programe to not function properly, i can not access or write a new sms. i have deleted the sms that caused the crash but i still cannot access the sms.
Even i hv d same problem
I got a msg....which i guess...caused d problem... Whenever I press on the Sms, it will just open and close again. I can't
Hacked phone needs help also. Notifies there is a message, but when you go to open it, it simply shuts down. Cant send either
unabe to read, send sms from iphone 1.02
i got 1 sms last night, now i cant open my sms box...Please help me how to open it...!
Regards,
Saboor Mirza.
Last night i got 1 sms and now i cant open my sms box, cant send or receive massages..please help me ASAP!!!
Best Regards,
Saboor Mirza.
WHen i tap on the sms icon it goes to text messages screen but when i try to send an sms it reverts to icon screen. Even when I try to send an sms from contacts it does the same thing
I had the same problem and found a way to fix it without loosing anything. I have an unlocked Iphone with 1.1.4. This is very easy to fix. Go to "Installer" on your iphone. Then scroll down to "Squid" and install it. Squid is a file manager the works great. Once installed, click on and open the program. Scroll down to "var" folder, then to "mobile" folder then to "Library" folder, then to "SMS" folder. Now click on the "sms.db" folder. You now see a screen which you can "X" read, write and Exec for owner. X out all three under owner and hit "apply." Restart your Iphone and it you should see all you SMS messages.
my sms doesnt work!
I am not able to retrieve / read sms message
Think I might have received a corrupt SMS message which has blocked the whole SMS option, won't let me view the SMS mailbox. Any ideas?
iphone 8gb
Same problem here. can't open any sms's. When sms button is pushed, the writing menu comes up for a fraction of a second and then the main menu re-appears.
why does my iphone 3gs keep returning on home page ? in short i can't open my messaging i restarted it but its still keep auto quit...
