Macromedia Flash MX Logo
Posted on Dec 05, 2007
Scrollbar scripting Hi How i can make scrollbar by scripting
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 07, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
161
Points
Create dynamic text give instant name text then create two button up and down
give the script on up button
on(release)
text.scroll -=1
give the script on down button
n(release)
text.scroll +=1
Remove mini scrollbar
The touchpad settings can be changed in control panel -> mouse
Here you have to go to last tab "Advanced" and click on Advanced setting button.
Now you should get a menu with all options available for touchpad.
There should be a option called "Use Scroll function". This should be checked/enabled.
How do I restore the down arrow on the scrollbar
Strange : are you viewing a page that is smaller than the screen so no scrolling is needed ? Or maybe you need to resize the browser window. what browser are you using ?
I have a problem with my scrollbar on my chat window
What version of yahoo messenger you are using, you might reconsider uninstalling it first and then installing version 10.0 from this link
http://messenger.yahoo.com/winbeta
This should solve the problem.
Kind Regards
1helpful
2answers
Mouse pad scrollbar on optima KN1 not working
try booting into your bios and see if there is a option, if not your trackpad and button unit thingy is probably synaptic, there may be a option in the mouse properties in the control panel
Touchpad scrollbar feature is disabled on my laptop
Hi there.
The keyboard toggle to reactivate the touchpad is Fn - F7
Please post back if the problem persists.
Good luck and thanks for using FixYa!!
2answers
HP Pavilion Entertainment PC - scrollbar on mouse pad not working
hi there.
maybe your mouse is not comaptibel with the system of your laptop or you need the disk driver to install the mouse to work properly?
or your mouse is already damage and need to replace try to change it with a new one.
Internet explorer script error,Scrollbar doesnt work on IM window
Hello.
Many of the problems with yahoo messenger are solved by following the steps on this help page especially the scrip error problem ->
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/notices/mstabuguqscripterror.html
Also it helps to have internet explorer set to be your default browser.
Hope this will help you with your problem.
Have a great day.
/Tech5508
26helpful
2answers
I think I can help you. I need to know what kind of mouse driver you are using. To find out click on the control panel, click on mouse properties, click on device settings. Under devices it should show Enabled/Name/Port. Under Enabled it should say Yes. Under Name should give the name of the device being used and under Port it may or may not show anything. Ex. Yes /Synaptic TouchPad V7.2 / Port/2. If this is what yours shows, double click on the highlighted device and a menu will come up. From there you can reactivate your scrollbar. If yours does not show a device in the list, sometimes it will show where to go to download the device in the bottom righthand corner. EX:(www.synaptics.com) If not, you will have to find the name of your device. Hope this helps. Tim
2answers
LG990 scrolling
Scrolling is different for many of the different lists you'll see. In some lists, such as the Artists in the Music Player, you 'drag' the list up or down, by dragging the last or first items respectively.
In All Tracks, strangely, dragging the list doesn't work. You'll have to use the scrollbar on the right. As far as I've seen, dragging will not work if a scrollbar is present.
In most lists, scrolling with the jog dial on the back should also work. There are lists which don't respond to the jog dial, but that is usually when the volume would be changed instead (eg. browsing the playlist when listening to music).
But at least one of the above three should always work. Hope that helps.
Scrollbar
The Ency. installs but the scrollbar is missing on the right hand side of the topic. Unable to read the entire article.
Top Macromedia Computers & Internet Experts
Rob Hill
Rob Hill
ADMIN Eric
ADMIN Eric
Are you a Macromedia Computer and Internet Expert? Answer questions, earn points and help others
