Whenever I try to open my JavaScript app on my tablets or my phone, I get a screen that shows: console.log('Hello'); on all three devices. I have enabled JavaScript on the settings of my internet browsers on all three devices, with no results. Can anybody help me with us?
If its chrome go to chrome://flags and it might be there but if you want to enable the java for the device you cant. Samsung boot locks their devices and doesn't allow you to, also doesn't allow you to go into the recovery system. But you can view your recovery logs along with a few other things by turning the device off and holding home power and volume up key for a few seconds after the screen turns on than let go. You should see a screen with some option use volume up and down to move and power to select.
SOURCE: How do I enable javascript
The option for this is found inside your web browsers settings. While in the browser, press the "Menu" button. Then select "More" and then press "settings". While in settings just click on the option that says "Enable JavaScript" and then you're done!
Good luck! And please, if you do find this answer helpful give it thumbs up :)
SOURCE: Javascript is enabled but it keeps telling me I need to enable it
On IE, clcik Tools>Manage Add Ons.
Is Shockwave Flash Object enabled? Is the file Flash10a.ocx?
SOURCE: Please Check Browser Settings
U need to first check all the settings to browse internet...... 1) Create ACESS POINT(Settings>Connectivity>Access Points). 2)Create INTERNET PROFILE, with accesspoint as created above(Settings>Connectivity>Internet Profiles). 3)Setting Up PROFILES in Browser, with Intrenet profile created in step 2(Utilities>Browser>Settings>Profiles)
SOURCE: unable to open internet browser in samsung corby -
I dont have any answer for this but I refer you to download opera mini Or bolt browser. so, you can browse internet on them.
SOURCE: i have installed ebuddy on
You do not have settings for internet connection. Contact your provider for the correct settings.
