Shubha Bundela Posted on Nov 29, 2017
What is difference between angular 2 and angular4
Anika Digital
Level 1:
Habit-Forming:
New Friend:
  • Contributor 20 Answers
  • Posted on Feb 05, 2019
Anika Digital
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
20
Questions
0
Helped
1337
Points
78
Angular 2 has the following features:
  • Angular 2 is based entirely on components - Angular 2 is entirely component-based so that controllers and $scope are now dead. The $scope will be removed in Angular 2.0 in favor of ES6 classes
  • Support for TypeScript- you get access to all the advantages, libraries, and technologies associated with TypeScript.
  • universal server rendering -
  • Improved Data Binding
Angular 4 has the following features
  • Faster and smaller - Angular 4 is now faster and smaller!
  • Animations now have their own package i.e. @angular/platform-browser/animations
  • Templates - a template is now ng-template. you should use the ng-template tag
  • Email Validator - In Angular 2.0, we use an email validator, using pattern option. but in Angular 4.0, there is a validator to validate an email.
  • Angular Universal: it's possible to render Angular applications outside of the browser.
Thanks
Anika Digital
1 Related Answer
saravanaguma
saravanagumar
  • 29 Answers
  • Posted on Aug 07, 2018
SOURCE: What is the difference between AngularJS, Angular 2, and Angular 4?
  • AngularJS is an open-source, JavaScript-based, front-end web application framework for dynamic web app development. It utilizes HTML as a template language. By extending HTML attributes with directives and binding data to HTML with expressions, AngularJS creates an environment that is readable, extraordinarily expressive and quick to develop.
  • Angular is the blanket term used to refer to Angular 2, Angular 4 and all other versions that come after AngularJS. Both Angular 2 and 4 are open-source, TypeScript-based front-end web application platforms.
  • Angular 4 is the latest version of Angular. Although Angular 2 was a complete rewrite of AngularJS, there are no major differences between Angular 2 and Angular 4. Angular 4 is only an improvement and is backward compatible with Angular 2.
  • Angular training in chennai
Best Angularjs training in Chennai Angular 5 Training
6answers
What is the difference between angular 2 and angular4?
Angular JS is the best JavaScript framework to develop dynamic web applications with great functionalities. As Angular completely depends on Javascript and HTML, one doesn't require to be skilled in other languages. Well, Google has released up to 5 versions in Angular having different feature specifications. Let's see the difference between Angular 2 and Angular 4:
Email Validator: We use an email validator in Angular 2.0 using pattern option, but there is a validator for email validation in the upgraded version Angular 4.0 Smaller and faster: Angular 4.0 is smaller and faster as compared to Angular 2.0
Typescript: Angular 4.0 is compatible with the e latest version of Typescript 2.1 and Typescript 2.2 while Angular 2.0 uses version 2.0.
Along with this, there are many other parameters where we see the difference between Angular 2.0 and Angular 4.0
Concluding this, Angular is a revolutionary technology, hiring a dedicated and skilled Angular developers team will make the web development process easier and more effective.
The spindle of a mixer rotating at 1500rad/min slows down uniformly to 700rad/min while making 40revolution,. Calculate the angular acceleration
Use the equation linking the final angular velocity and the initial angular velocity
(omega_final)^2=(omega_initial)^2+2alpha(theta_ final -theta_initial)
Each revolution is 2PI radians.
Changing rad to degrees mode on fx82mu
fx-82MU?
If you mean fx-82AU, press SHIFT [SETUP] then 3, 4, or 5 to select the desired angular mode.
If you mean fx-82MS, press MODE then 1, 2, or 3 to select the desired angular mode.
Casio calculators almost always have the angular mode in either the MODE or SETUP menus.
Ho do I get DEG off of my calculator
Change to a different angular mode. Press the DRG key, use the left/right arrow to select the desired mode, then press ENTER twice.
Be aware that whatever angular mode you select, the display will show either "DEG", "RAD", or "GRAD" to indicate the mode.
How to get rad off
Set a different angular mode. Be aware that another angular mode will still display something to indicate the mode.
Can get rid of DEG
This is merely telling you that the calculator's angular mode is set to Degrees. No matter what angular mode you set it to, one of the indicators will be lit. You can press the DRG key to cycle through the different modes, and the indicator will change accordingly.
What do i punch in get a decimal answer from tan 19 degrees 45'
If you have the angular mode set to degrees,
TAN 1 9 2ND [ANGLE] 1 4 5 2ND [ANGLE] 2 ENTER
If you have the angular mode set to radians,
TAN 1 9 2ND [ANGLE] 1 4 5 2ND [ANGLE] 2 2ND [ANGLE] 1 ENTER
10helpful
Cant push back cylinder on rear brake caliper on vw golf 1.4s
You will need to check to see if your VW has anti-lock brakes installed on it. The pistons that push in usually look like an inverted cup, hollow end facing the brake pads. The pistons with antilock brakes are usually solid across the top facing the brake pads and will need to be rotated in order for them to collapse back inwards. Some rotate easily, others are a bit more difficult. The pistons on my VW Beetle have two (2) angular grooves opposite one another. If your look like this you may be able to use the blunt end of some needle-nose pliars, or you can head over to your local auto parts retailer for a "magic box", a square cube with as many as five (5) different patterns for the buttons that insert into the angular grooves on different vehcles. Find the pattern that best fits your grooves and attache the magic box to a 3/8 rachet with an extension. Rotate the piston slowley in one direction, then the other to loosen it up. To collapse the piston I believe you will need to rotate counter clockwise. Good luck, this style piston is only on the rear wheels.
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
