Apple iPad (16 GB) WiFi Tablet PC Logo
D
Donald Mohapanele Posted on May 24, 2016
How can i get passcode
I forgot my passcode
Denis Russo
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 10, 2016
Denis Russo
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
196
Points
Hi Donald. Do you forget the passcode?
If you have synced your iPad with iTunes before you forget your iPad password, you can reset your iPad by using iTunes without losing data. Through iTunes, you can restore your iPad from the last backup and remove the passcode from your locked iPad while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPad Passcode with Recovery Mode section below. The following steps will show you how to reset iPad password with iTunes.
  1. Connect your iPad to the computer with via a USB cable that your iPad has trusted.
  2. Launch iTunes. If you've synced your iPad with iTunes, then no "enter password" is required.
  3. iTunes will automatically sync your iPad and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
  4. In the Summary window, you can see the option "Restore iPad". Click it and follow prompts to choose the latest iTunes backup to restore your iPad.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPad without any passcode. And you can set your new password on iPad.
How to Reset Password on iPhone
2answers
I forgot my ipad passcode and never synced to a computer
If you forgot your iPad passcode and never synced it with a computer, don't worry - you can still unlock it. The only official solution is to erase the iPad and set it up again, because Apple cannot bypass the passcode without wiping the device for security reasons. Here are the working methods: Method 1: Use iPad Recovery Mode
Step 1 - Turn Off the iPad
Step 2 - Put iPad into Recovery Mode
For iPads with Home button
Hold Home button while connecting to the computer.
Keep holding until recovery screen appears.
For iPads without Home button
Hold Top button while connecting to the computer.
You'll see a computer + cable icon.
Step 3 - Restore the iPad
Open Finder or iTunes.
A message appears saying:"There is a problem with the iPad..."
Click Restore (NOT Update).
Method 2: Use Third-party Tool Like TunesKit iPhone Unlocker It is an unlock tool for unlocking iPhone screen lock without passcode wtih a few clicks. main-interface-tjcucf33m5ls2riadgag3o1k-d-0.jpg
Passcode is required to enable Touch ID on Ipad
This is plain and simple - you need the original passcode before you can add your fingerprint. If this was a used tablet - you can get the passcode from someone that has it - or you may be able to factory reset it using itunes and recovery mode.
Forgot passcode for your iPhone iPad or iPod touch or your device is...
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
Set it up with thumb print when Iopened it up wont let me in without 6 digit passcode which I don't have
Well, when you first set up your IPad you had to create a passcode to get in. If you can remember what your passcode is click the link here and reset it. Forgot passcode for your iPhone iPad or iPod touch or your device is...
Forgot id and password
If you forgot the passcode for your iPhone, iPad, or iPod touch, or your device is disabled Follow these steps if you've forgotten your passcode, or if a message says that your device is disabled.
Forgot passcode for my kindle
Try the methods listed here: http://askville.amazon.com/reset-password-kindle-forgot/AnswerViewer.do?requestId=82179081
Forgot passcode for ipad mini
There is really no option except to erase the iPad with iTunes. It is a security feature that is built into the iPad operating system. You can follow this guide, although it says it is for iPhone, it applies to iPad too!
http://support.apple.com/kb/HT1212
Forgot my ipad passcode
If you are locked out, you have to connect to iTunes and do a reset/restore. You can follow these directions from Apple:
iOS Forgotten passcode or device disabled after entering wrong passcode
I forgot my password for my hisense smart tablet how do i reset it or open it again?
Have a hisense tablet and forgot the passcode how do I reset it I tried the reset button but it just turns it off want get past the passcode
2helpful
Forgot restriction passcode on apple iPad 2
There is no way to unlock it as a passcode also prevents other people from unlocking it to access your data. What you could do is put it into recovery mode and then do a restore which will wipe all data, assuming you have a backup, you can just restore the data.
Top Apple Tablets & eReaders Experts
john h
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
