Dishwashers Logo
K
Koh Sok Hwa Posted on Jan 14, 2016
What is causing E5 error code?
Initially thewater supply was having problem. The E5 error code came on. but I just fixed the water supply and try to use the machine again.. the E5 code still appear and the 3 lights on theheavy duty, normal, normal-eco lights keeps blinking. please help anyone!! Thanks in advance-helen .
5 Related Answers
Anonymous
  • 725 Answers
  • Posted on Aug 25, 2007
SOURCE: Lights blinking and won't clear
the solution #3 should work.. you may want to try again.... first turn off the Breaker to cut power then wait a few minutes then turn back on, then within 6 seconds try (Heated dry)(normal)(heated dry)(normal).. all lights should light up then you know that you are in the service cycle, and the unit should go into a self test and clear the fault. The test take about 30 minutes. let me know if you can get into it...
ekauffman
Elisabeth Kauffman Humphrey
  • 3 Answers
  • Posted on Mar 22, 2008
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Anonymous
  • 15935 Answers
  • Posted on Sep 21, 2010
SOURCE: Error code F4
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Anonymous
  • Posted on Sep 25, 2010
SOURCE: dishwasher error codes please help
ive got the hotpoint fdw60 with the fast and delicate light flashing can any one help please
Anonymous
  • 4323 Answers
  • Posted on Jun 20, 2011
SOURCE: My Bosch Eco Sense dishwasher shows error code
Hi
E24 error indicates draining failure and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Hope this helps... Please post back for any further assistance.
Daniel
Top Fisher and Paykel Dishwashers Experts
Sudeep Chatterjee
Sudeep Chatterjee
Paul Bade
vince
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
