Google Nexus 7 Logo
Sukmoon C. Posted on Mar 26, 2015
How to replace screen?
My Nexus7 screen was broken, how do I replace?
My nexus7 ASUS tablet turns on but the display of apps is frozen. How can it be fixed? Ken
Hi u might have to reset ...,to factory settings.
but before u do try putting tablet into
SAFE MODE .Press power button till
turn off icon is on ..touch the icon & a
safe mode icon will open .
press ok..cheers
1helpful
Why does my nexus keep closing down on Facebook with the new Android updaet
I would try uninstalling the Facebook app and re-installing it and see if this fixes the issue. Before doing that however make sure that the tablet has been fully powered off and restarted if you have not done so since the update was installed - that may also cure the problem.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
How to reset to factory settings
You don't say what tablet you've got, but this works on Nexus7 with Android operating system. No harm in trying it.:
Hold down the on/off switch. The system will go into shut-down. KEEP HOLDING THE SWITCH DOWN. After 15-20 seconds you will get the start-up screen as it reboots. You can let go now.
You have reset to factory settings but all your apps and data should still be in place. They are on a Nexus, anyway. I take no responsibility if this doesn't work on your system.
How to connect to home wifi on nexus7 android 4 strong signal ,saved, secured but cycles between connectiing and no IP address. How can i FIX?
Hi Noha, sometimes a router might have too many stuck sessions, reboot it to see if you can connect with your devices.
If it stays stuck on 'no IP address', there seems to be an issue with your broadband connection.
Hope this helps.
I cant activate a kindle fire
does it locked?
Well, can you find the girl? if so then let her help you.
Or else you could try to Amazon support, but I don't think you can get help from there.
If were I, I would like the iPad.
iPad mini vs. Kindle Fire HD vs. Nexus7: Best 7-inch Tablets Comparison
1helpful
Nexus7 will not connect to the internet after latest update
To update you on my Nexus7 not connecting to the Internet was solved by pressing the button on my router and also pressing the two arrows (that form a circle on my Nexus) at the same time and it connects right away.I hope this helps other people with the same problem.....Colin Bett
1helpful
Can you connect nexus7 to your pc
Yes with the USB cable that came with the Nexus7 charger. It looks like any external storage eg digital camera so you can copy and delete stuff through the PC.
3helpful
Charging problem google nexus 7
i have a problem with my nexus7 and it want charge or turn on please help me with this problem
Top Google Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
Jeff richtman
Jeff richtman
Are you a Google Tablet and eReader Expert? Answer questions, earn points and help others
