ZEEPAD New 7 inch Epad with android 2.2 tablet pc includes WiFi 720p Video Logo
R
Rocky Perkins Posted on Dec 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to replace the battery for my zeepad - ZEEPAD New 7 inch Epad with android 2.2 tablet pc includes WiFi 720p Video
Steve Sweetleaf
Level 3:
  • ZEEPAD Master 1,214 Answers
  • Posted on Dec 29, 2014
Steve Sweetleaf
ZEEPAD Master
Level 3:
Answers
1214
Questions
5
Helped
442012
Points
3488
How do I turn on zeepad
Press and hold the power button until the display lights up with a symbol of some kind. If that does not work it probably needs charging or a replacement battery or servicing.
My zeepad doesn't want turn on
I'm not familiar with your particular tablet, but I have one that occasionally acts this way. If I leave it on charge a couple of days, it usually comes back and works. I've replaced the battery, and it still does this on occasion. Most the time it is okay. I hope this helps, but if you need to replace the battery, find one on-line and perhaps we can help with instructions on how to replace it. I hope this is helpful.
2answers
How to extend the short battery charge on Zeepad
You can decrease LCD brightness to improve you battery time
1helpful
Why wont my zeepad charge all the way?
Battery getting old and need of replacement , is the typical reason for devices to no longer charge correctly.
Why wont my zeepad turn on
Check the battery is charged - it may be duff and nee replaced if it is not charging or your power adaptor may not be charging it - check it with a multimeter - the power socket on laptops andf tablets are very susceptible to damage - if that fails then plug it into a pc using the usb port - it will charge very slowly as usb only has a very low charge current but be patient and if it charges up after 12 hours using the usb method you will know one way or another whether its the battery or the power socket or charger.
Where is the battery located at in a zeepad
The battery on the zeepad 7.0 is located inside,first turn off unit then take a fine blade insert the blade ever so gently between the edge you'll see the seam with the blade inserted pry downward along the edge you'll hear it pop open as you pry down.
2answers
Zeepad 7.0 Jelly Bean can't connect to the wifi
my zeepad will stop or go in sleep mode when on it is there any thing i can do to fix it.
2answers
My zeepad 7.0 battery is dead
Hi, Zeepad battery is PBS01SHz10 is a japanese battery, similar to nokia BL-5k battery.
Open a zeepad is easy, the problem to find these kind of battery. I am thinking in change the internal connector to adapt the nokia n86 battery, is more easy to find almost here in Venezuela.
2helpful
3answers
How to remove battery from zeepad 7.0 tablet
Hi open a zeepad is very easy, you need apply some pressure over the case and the screen. I recently open my sons tablets. regards.
Top ZEEPAD Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
 Mikey
Mikey
AJ ZONE LK
Are you a ZEEPAD Audio Player and Recorder Expert? Answer questions, earn points and help others
