Dishwashers Logo
A
Anonymous Posted on Aug 01, 2014
Se code My samsung model dmr57lfs dish washer gets a se code and my drain line is not kinked. I was looking to see how to removed the drain line so maybe I could blow it out. I haven't had a problem with water staying in the tub
Ronald Rissel
Level 3:
Master:
  • Samsung Master 715 Answers
  • Posted on Jan 31, 2015
Ronald Rissel
Samsung Master
Level 3:
Master:
Answers
715
Questions
Helped
264105
Points
1075
You're on the right track - SE error code on a Samsung dishwasher means "drain error". If you can get to it, try removing the drain pump. Chances are there is something in it that is blocking or impeding the impeller, or may be stuck at that end of the drain hose (where the check-valve is located.) Good luck!
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
5 Related Answers
ginko
Ginko
  • 19396 Answers
  • Posted on May 21, 2009
SOURCE: Water not draining completely from Dishwasher tub
That usually happens because of a faulty water level sensor, check it out.
Dalton Jones
  • 118 Answers
  • Posted on Aug 05, 2009
SOURCE: botttom of the tub is filled with water,not draining
there is a switch that opens and pumps the water out, check that the switch is working. If not, replace it.
Anonymous
  • 6784 Answers
  • Posted on Aug 26, 2009
SOURCE: dish washer wont drain
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Anonymous
  • 74 Answers
  • Posted on Nov 02, 2009
SOURCE: du401 doesn't drain water
there is a little pump at the bottom of the machine,called the askoll pump".this is what pumps out water before and after a cycle.the pump needs replacing.
Testimonial: "Thank you for your post. This is out of my area of expertise and I'll have to call the repairman on this."
Anonymous
  • 6 Answers
  • Posted on Feb 10, 2010
SOURCE: doesn't drain
it may be something to do with ur plumbing might wanna get it checked.
Top Samsung Dishwashers Experts
vince
Paul Carew
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
