The error code "22.0;10" on an HP DesignJet T610 44-inch printer indicates a problem with the printer's ink supply station. Specifically, it suggests an issue with the Ink Supply Tubes System.
Brivis Error Code 44 Roll out: During an ignition a flame rollout signal is detected and the maximum rollout events allowed has not been exceeded. Reason: During ignition a flame roll out has occurred where the flame has earthed the antiflame roll out (AFRO) bar to the burner assembly.
Error Code 44 is caused when the program that you are using shuts down the peripheral device installed on your system. It is triggered by the following: ... Device driver files are outdated. Device driver files are missing.
Did you actually have an error code for the O2 sensor?
You have a fuel delivery issue
Clean Throttle Body
Clean MAF mass air flow sensor
Clean the injectors
Fuel Air Sensor is the one that regulates fuel to injector and is on the exhaust manifold. The O2 sensor checks what's left after the Catalytic converter to make sure the unburnt hydrocarbons have been used up for emissions purposes
It's all in the Codes, but Error 44 has no context without the vehicle it came from.
Oxygen Sensor Error (Lean Condition Indicated)
The ECM receives a signal from the O2 sensor based on the amount of oxygen in the exhaust. If there is excess oxygen in the exhaust, it is in lean condition and the O2 sensor voltage will be low. The ECM uses this information to adjust the amount of fuel delivered to each cylinder. Fault Code Description
Precor Error 44, Un-commanded Lift Motion
Probable Cause
1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Probable Cause
Corrective Action
Probable Cause
Corrective Action
