SOURCE: cant remember my passcode for my ipad
plug it into the original computer that you set it up with and through itunes you will be able to reset it. Once the ipod appears under devices click on the restore button it will indicate that you can restore settings etc. If it is not the original computer that you are using you will be able to reset it but will lose the information on it. Hope this helps.
SOURCE: How do i reset my locked iPad?
if u r having software of that i pad u can use it with datacable and then format it
SOURCE: my ipad is disabled how do i fix it
Try connecting it to iTunes, turning off the ipad, then hold both the lock and the home button for 10 seconds, then relese the lock button while continuing to hold the home button until iTunes recognizes the iPad. Then you should be able to reset it without problem.
