Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125 Logo
Jamie Ellis-Pacheco Posted on Mar 03, 2014
C7 error code
I have a Bosch Aqua Star GWH 2400 ES NG with Error code C7. Ran through diagnostic, 5D = 00. What does this mean?
quattro1869
Level 1:
  • Contributor 30 Answers
  • Posted on May 06, 2014
quattro1869
Contributor
Level 1:
Answers
30
Questions
0
Helped
10187
Points
32
C7 code has to do with your main fan. Either its not working due to it being blocked or having gotten wet/damaged/power surged, or your control unit isn't supplying the correct 120V to the fan. Your control has a ceramic fuse that you can test as well.
First, look for 120V to either the left or right pair of wires in the molex plug on the fan. if you have voltage, then the fan is bad. If you dont, its either just a fuse, the board is bad, or the fan is bad causing the fuse to blow. Insert the supplied spare fuse, and power up the unit. If it blows the fuse again, its the fan.
5 Related Answers
jaytee521
  • 8 Answers
  • Posted on Feb 05, 2010
SOURCE: error codes re: fan speed fan very noisy
I was looking for a service manual, which you apparently do not supply. I was not looking for someone who will charge me a fee to get information. I can get that info directly from Bosch for free. Thank you for answering. John
kendji9
syaiful ridlo
  • 112 Answers
  • Posted on Jan 22, 2011
SOURCE: We have the model gwh-635-es the error code E1
its the warm stabiliser is not work
Anonymous
  • 43501 Answers
  • Posted on Feb 03, 2011
SOURCE: Bosch tankless watwer heater GWH
The unit is plugged up with mineral buildup from the water going through it... it will need to be cleaned internally....this is done by running an acid solution through it to clean out the mineral buildup...
Then it will work again...
heatman101
A
Anonymous
  • Posted on Apr 12, 2011
SOURCE: i have a bosch gwh
Before calling service technician, open following link to download typical manual, get Bosch contact information etc.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
A
Anonymous
  • Posted on Aug 14, 2011
SOURCE: I have a Bosch Tankless
Yes. Contact Bosch.
Error codes are considered start-point for troubleshoot.
Tankless are complex electronic machines.
If on-site plumbers cannot figure out problem, then you need trained service technician with a service manual for your specific product, who can ohm-test the electronics.
Bosch will have a list of trained service technicians. And maybe Bosch has another step for fixing problem yourself.
Fix most tankless problems yourself, same day, for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
My GWH 715 ES cannot restart after hot into cold water crossover
Check for obstruction in your watervalve. It has a flow meter, that needs to spin freely. Remove the watervalve and blow through it, you should hear it spin.
Also make sure you dont have an error code showing. Hold down your reset button for 5 seconds to reset an error code and get back to your set temp.
2answers
I have a Bosch Tankless Water HEater Model GWH 2700 ES NG with an error code of A3. I was told to push reset and the problem would be resolved. This worked several times and now it doesn't work. ...
Yes. Contact Bosch.
Where can i download a GWH 715 ES manual?
Are you looking for sell sheet pdf, or install-care manual, or service manual.
Search: GWH 715 ES manual .pdf
Adding .pdf to search parameter helps locate manuals.
Sell sheet with venting overview, technical and product specs:
http://www.globaltowne.com/manuals/sell_sheets/715-800SellSheetFINAL.pdf
Manual for ES high altitude, with installation, error codes and troubleshoot:
http://www.bosch-climate.us/files/201009031238250.GWH715ES_English_12.2008.pdf
I cannot find a service manual, or service bulletins:
http://www.bosch-climate.us/support-center/downloads/bosch-manuals/earlier-models.html
I have a bosch gwh 2400 es ng and when i program the temp. it resets back to 100 degrees
1helpful
What does Error code A3 mean and how to correct it ?
http://www.bosch-climate.us/files/201008311810050.G3-11_A3-E3_Error_Code_Troubleshooting.pdf
Check out Link for help.
I have same problem.
Error codes re: fan speed fan very noisy
2helpful
Bosch on demand tankless water heater gwh 2400 E LP error code "
BOSH AQ 250 On demand propane water heater ran out of propane, got gas now, but get EC flashing on the display and the unit won't fire? Lost manual, any suggestions. Thanks, Jim
Bosch Pro tankless water heater overheating
The vent pipe you use is the correct size for the heater.Longer runs require bigger pipe.I also would check to see if the water is getting to hot.
Top Bosch Water Heaters Experts
john h
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
