How to Fix NTLDR Errors
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
Try replacing the IDE cable cable if you suspect it might be faulty.
If you can't gain access to your files to back them up, understand that you will
