Washing Machines Logo
A
Anonymous Posted on Jan 17, 2014
Code error f02 e08 - Washing Machines
5 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Jan 25, 2008
SOURCE: HE4t Elite F02 error code
its the error code for a long drain time most likely you need to check the filter in your pump for obstructions First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
Anonymous
  • 185 Answers
  • Posted on Mar 25, 2008
SOURCE: error code f02
the f 02 means you have a long drain issue press pause/cancel twice to clear the display check drain hose make sure it isnt plugged or kinked check electrical connections at the pump make sure the pump is running check drain filter for foreign objects if the above does not correct the problem replace the pump
Anonymous
  • 15935 Answers
  • Posted on Sep 29, 2010
SOURCE: showing f02 error code...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
Anonymous
  • 15935 Answers
SOURCE: error code f02 comes up
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.A(*$^&
richroth
Richard Roth
  • 9472 Answers
  • Posted on Oct 18, 2012
SOURCE: Hoover WMH168D error code E08
E08 = Tacho fault
The tacho coil is on the motor and is fitted at the opposite end of the drive belt where the carbon brushes are. This error says something is wrong regarding the tacho coil but it doesn't specify exactly what. Possibilities are varied so unless you know what you are doing, and unless you can see something obvious like the coil has come away from the motor or the motor or drum has seized up it is probably better to call in a professional.
Resistance readings for tacho coils are usually quite high, so if you don't have a sensitive enough meter it could appear to be open circuit when in fact it's reading over 150 Ohms or more and may be ok.
In conjunction with a magnet fitted on the end of the armature shaft each time the motor does a revolution it can be counted by the software or pcb through the tacho coil. This information is used to judge and control the speed of the motor at all times.
If the coil is open circuit the washing machine would lose al control of the motor and in the past the motor would often spin uncontrollable causing damage to the washing machine. These days if an open circuit or missing tacho coil (they can fall off the motor) is detected the machine will stop working and report an error code.
Top Washing Machines Experts
AskDyson
AskDyson
ADMIN Andrew
ADMIN Andrew
