Carrier 48 000Btu ceiling cassette inverter has an EE error code please with a solution
Try looking at the manual. you might be able to find the manual here.
if that doesnt help then try leaving a message on the site with the manual you need and they will upload it for you.
Hi the manual says water-level alarm malfunction. we have changed the pc board and the condensete pump still no joy
What cost of EE ERROR
What is PC board condensete
SOURCE: Error code E39 for Mitsubishi Heavy Industry Ceiling cassett type
E39 Fault is thermister, Mitsubishi way of saying im not going to start because there is something wrong. Generlly it is compressor fault or short of gas. Im guessing if you turned the power out. Waited twenty seconds, turn it back on. Now if you go to the outdoor part. Wait exactly 3 mins. If you hear the compressor try to start and fail then it would more then likely be your compressor if you dont hear anything and the unit faults out it will either be a board or short of gas.
Either way If the unit is under five years old get a warrenty agent out to look at it.
Sorry I couldnt tell you for sure but MHI are very vague when it comes to fault codes
SOURCE: Error code CH 02 for a ceiling cassette model
CH02- Means "Indoor coil sensor is faulty or not connected"
Testimonial: "thanks for help i will keep you posted when ever I have a problem"
