Wrong cartridge
Nice Printer.
First of all, see if its reading on the computer, if not, try and hold the power on the printer untill it shuts off, and then turn it back on again. Also, you might want to check the troubeshooting section if you have the manual
If none of the above works, try getting a replacement cartrige. if the connectors on the cartrige get messed up, the printer may not read the cartrige properly. Make sure the printer's connection to the cartirdge is ok too. If you know someone who has the same printer, try the "ERROR" cartrige in that printer. if it works, then your printer needs to get fixed. If it doesn't work, get a new cartrige and all should be fine. Don't get the cartrige refilled if it doesn't read in a nother printer, you need to replace the cartrige!
