Janome Magnolia 7330 Sewing Machine Logo
A
Anonymous Posted on Nov 30, 2013
Error code fc - Janome Magnolia 7330 Sewing Machine
Singer Futura XL-550. Error code 08
There is no data available on Error Codes in general or on Error 08.
https://www.google.com/search?q=Singer+Futura+XL-550.+Error+code+%2208%22
https://www.google.com/search?q=Singer+Futura+XL-550.+Error+codes
It is not even in the Service Manual, which does mention codes, but not 08.
Error code list
Error
06
Feed step motor
09
Zig Zag Step motor
16
Cutter step motor
https://www.manualslib.com/manual/739440/Singer-Futura-Xl-550.html?page=31#manual
If the error goes when you remove the embroidery unit is is likely to be a positioning error when the machine is lost to where the needle is in position to the frame.
1helpful
Babylock Soprano. Has error message F04 FC BREAK. Red light is on so machine is not working
This could be an easy fix or not. The error indicates that the sewing machine can't communicate with the foot controller. A new foot control is ~$30, https://www.sewingpartsonline.com/babylock-blmsp-soprano-sewing-machine-parts.aspx?index=104 . Unfortunately, the problem could be the jack or the control board on the sewing machine. Unless you have the electronics skills to ground yourself to the sewing machine (and safely discharge high energy capacitors), you may need to take this to a qualified sewing machine repair professional.
I hope this helps.
2helpful
2answers
Brother NX-400. Never used. Error F04. I've looked for a model # for the foot for NX-400 to no avail. The foot that came in the box is Model T/FC-322. I can't help but think this is the wrong foot.
If you mean the foot controller, then the T/FC-322 is a substitute that should work. It's listed as a replacement here: http://www.sewingmachinesplus.com/234522001.php . The manual for the NX400 gives the foot controller as XC1154-051 . Brother changes the part number often but the wiring remains the same. Another substitute controller is available here: http://www.sewingpartsonline.com/foot-control-w-cord-brother-xc6651121.aspx .
The F04 message may mean there is an internal failure. This probably needs to be fixed by a Brother authorized repair person.
I wish that I had better news for you.
In the window then note comes up E1 ERROR . What is this. It does not sew.
Consult the owner's manual. There is usually a list of error codes in the Troubleshooting section that discusses error codes and how to resolve them.
Error Codes differ from brand to brand, so it is best to search for your machine's make, model plus "E1," ie:
Frequently Asked Questions
Why is my Kenmore sewing machine locked up with an E1 error code displayed...
Simple Fix for Janome E1 Error
I have the fault code FC come up - the machine almost 'takes over' it speeds up & stitches on its own without my foot being on the pedal, I have unplugged the foot control & am wondering if...
Mine was doing the same today. Took the foot pedal screw out and ran some nail polish remover over the contacts (where the pedal slides when it's in use) bingo. Sorted it with no expense spared.
1helpful
I have a Janome DC 2010. The machine has started to continue to sew even when my foot is off the foot control. I turn the machine off and then back on and it goes to error message fc....then goes to...
my book show the FC stands for Foot Control
have you tryed repluging the foot control into the machine to see if that stops the problem
if you have & it didn't stop the problem
then I agree you need a new foot control
Keeps giving me the Fc warning signal no matter what I do
The foot control has been disconnected while sewing. Turn off te power and connect the foot control.(connected to foot pedal on the floor has come loose from machine body)
I cant get the machine to sew a buttonhole.
I am not familiar with your machine, but some buttonhole attachments require a lever be lowered and inserted into a tab.
Review your manual to see if a step was overlooked.
2answers
Eurovox codes 54 01 needed for 2/11/2008
Make sure u get the rite NTL codes
These codes are from the 4th of December. nt the 2nd as u reuested. have changed sinc :)
LATEST KEYS ALL AREAS
EX C&W KEYS -- KEYROLL 04/12/2008
PROVIDER CODE: 5C 01
KEY 00 = D4 A3 5D EB 7B F3 69 59
KEY 01 = 27 77 A1 FC 8F 9D 34 76
TELEWEST KEYS -- KEYROLL 04/12/2008
PROVIDER CODE: 5A 01
KEY 00 = C0 F6 61 87 91 F9 67 57
KEY 01 = F0 83 35 E5 28 40 49 B2
PURE NTL KEYS (UK) -- KEYROLL 04/12/2008
PROVIDER CODE: 54 01
KEY 00 = 3F B8 36 62 72 E5 E2 76
KEY 01 = 35 5E D6 40 6E AA 99 41
IRELAND CHORUS KEYS -- KEYROLL 29/06/2008
PROVIDER CODE: 5E 01
KEY 00 = 51 0F 32 A7 D9 34 BE 3E
KEY 01 = 8D A3 88 1B 4E 32 C5 8F
IRELAND NTL KEYS -- KEYROLL 18/06/2008
KEY 00 = 75 92 B1 CC 6F 23 20 F1
KEY 01 = F2 46 B1 59 04 61 77 71
Top Janome Sewing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Rommel Balcita
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
