I forgot my security code using Nokia 1100... i want to change my SIM card/mobile number... how can i reset the security code... I already research master security code using my IMEI number, i tried the MSC but didn't work... (code error) please help me to get or reset the security code... My IMEI number is 357593006548708.... the master security code which is generated in internet to reset is 0204376647.. Hope to solve it ASAP....
Hi freinds
i have nokia 1100 phone ane my imei is 35793000/200543/4 and i had for got my security code can some one help me to reset it and can you help to reset code for nokia 1100 phone
Hi i need a phone unlock code for 1100 which was locked by some of keyguard lock please give me an unlock code my imei no is358849004335046
I forgot my nokia 1100 mobile security code please tell me the how can i reset the security code
my mobile imei number is 358363005657929
Sir i have a nokia 5300 phone i want security code my imei no. is 354848013988773
I have no idea to reset nokia security code,
but i have and alternative to unlock ur nokia 1100.
Method
1) just dial 112 from your nokia 1100 when it is locked with security code, and press call button.
2) this will enable all the keys.
3) just switch off your mobile with red button, and switch on.
after this your mobile will not ask security code, till when you do not lock it.
i am iftekhar qurashi
my id is iftekhar_qurashi@yahoo.com
Boss you have to visit a repair shop and he will do a master reset in 2 minutes using a software no need to flash the phone, however you will loose all your numbers stored on your phone
First Trick : For Master code calculation http://www.nokialockcode.com/calculate.php and enter it to unlock. For IMEI *#06#
Second Trick :
1.press "unlock" button
2.then press "back"
3.then deep press unlock and then suddenly press *
4.that's all you unlocked the phone successfully.
NOTE: it will not work on all nokia phones so please check the nokia phones before practising the trick;but the trick can effectively work on most non java enabled nokia phones
Third Trick :
Remove Your Sim Card, Power The Phone On
Press # From The (Insert Sim) Screen
Enter codes WITHOUT spaces.
Press * 3 times fast for (p)
Press * 4 times fast for (w)
Press * 2 times fast for (+)
Verify code before pressing the last #
Fourth One:
The only way you can reset the security code is to take it to Nokia or some mobile store where they will reset it using a flash cable.
Enter this in your phone 3543561762 and your phone will be unlocked
Sir i hv forgotten my nokia 5300 security code. will u plz help me!!
i hv seen the master lock u suggest some one. bt i try it dose not work. plz give me my master code.
my IMEI: 354567011502945 plzz help me as soon as possible i m waiting for ur possitive response! thanks!
If u rnot getting ur phone unlocjed after internet generated code also u jut, take out ur sim and copy ur sim contact on other phone or somewhere else. then go to service centre and flash ur handset.
12345 is the default nokia security code
code... My IMEI number is 356671002488532.... the master security code
mail me majid_jatoi2000@yahoo.com
Go to Service center and UNLOCKED YOUR MOBILE
Dear sir i have nokia 3110c model .sir in my nokia 3110c mobile security code is locked,so please solved that problem.
I forgot my security code ,how do I get past the security code for my Nokia x2-01
Nokia 1100 security code error
How to apply the security master code
Hey im using 1100 nokia 7 ive forgotten ma security code so kindly help me
my imei number is 357078001075287
Thx it was really very helpful indeed
You must go to the service provider to perform soft ware updates it takes less thsn 5min.advise by DOGY
SOURCE: Resetting Security Code
i forget my pin code 2 ? im using 5310 ...my imei is ( 358653010809055 ) btw ........wads is master code ?
sorry but you will have to get a service centre to reset it back to default
Today I was buying nokia 5300 T-Mobile. And i have problem./ It's lock. Salesman
told me, that it is unlock... He deceive me... F...ck. Please, help me
if you can.
IMEI: 356959018795218.
Code 6003104322 isn't to work.
My e-mail is: kgojak@wp.pl
Best regards
Chris
i have nokia 1112
my imei no is 354573018881860 i want to reset my code
I forgot my security code using Nokia 1100... i want to change my SIM card/mobile number... how can i reset the security code... I already research master security code using my IMEI number, i even tried DCT4 Calculator 1.4 (software) but it didnt work now its givin code error please help me to get or reset the security code... My IMEI number is 355385008195642.... the master security code which is generated in internet to reset is 0325732507
Hello there i have a Nokia 5300 to which i ahve forgoten the security code. The IMEI No. is 352772019912532. Please help me
how i change my nokia 5300 imei number
I find out my master security code no which is 5117736350 using my IMEI no which is 358364004485494 and enter that master security code no where my mobile asked me 'enter Security code' but it doesn't worked. it again shows 'code error'. please give me a solution to solve this problem.
i forgot my security code
keyguard codes unlock
I forgot my security code using Nokia 1100... i want to change my SIM card/mobile number... how can i reset the security code... I already research master security code using my IMEI number, i tried the MSC but didn't work... (code error) please help me to get or reset the security code... My IMEI number is 355655008738678 the master security code which is generated in internet to reset is
YEs
i have my cellphone nokia 1100, my problem is, i cannot send text message
yas
i bought a second hand mobile.my model is nokia1100.
the first user has changed the keyguard code. so please help me to set new code.
I forgot my security code using Nokia 1100... i want to change my SIM card/mobile number... how can i reset the security code... I already research master security code using my IMEI number, but it didn't work... (code error) please help me to get or reset the security code... My IMEI number is 355655002294652.... the master security code which is generated in internet to reset is 2204223035.
need reset code for nokia 1100.imei 010642003049126
i want security code of my nokia 1100 IMEI 358802003507057 plz help soon thanx
I forget my lock code for nokia 1100.can u plz help me out
I have the same problem
i forgot the security code for nokia 1108.Msc is also not workin.pls any one help
security code error
i have nokia 1100.i forgot the security code.i tried through internet.but its generated one code.
problem not solved.iam writing my imeino:33753003100234
internet generated code:3373634652.pls help me in this issue.
i forgot my security code for Nokia 1100. I have tried the master security code which is 4474324413, but its still not working. My IMEI is 35883000833245.
i hv forgotten security code of my nokia 1108 and my phone is locked. please tell me a solution for this problem
the mobile is not taking code
my mobile is not taking the code and showing code error i have also tried the master code written on internet my bettery is broken and my imei number which was written on it has also been destroyed .so please help me]
my nokia 1100 serial no is
355029004615761
code... My IMEI number is 352524007166682...
hi,i m Usman from Pakistan and i have a problem with my nokia set model 1101, imei: 35880300 / 597602 / 7 , all over the cell phone there are security codes, and those codes i don't know abt them, i can't even delete and edit my mobile numbers, if some one could help me to remove these codesi will be very thankfull to him, plz my mailing address is mafiamirpur@hotmail.com reply me here. i m waiting for your reply.
nokia 1100
i forgot security code wht shud ido pls help. coolkarnips@gmail.com
i have nokia 1100.my phone is unlock with keyguardcode.let me know that how to open.my mail id is darshit_27@yahoo.commail me as soon as possible.
I HAVE NOKIA 1108
I WANT TO RESTORE THE FACTORY SETTINGS OF MY PHONE BUT FORGOT THE SECURITY CODE
CAN SUMONE ASSIST ME ?
IMEI NO. IS 358379007061043
I forgot my the security code of my cell phone(nokia 1100)
HI i've forgotten my security code for my nokia 1100 my imei is: 359399006984754 can u please help?!?
my email: shaheen.n@hotmail.co.uk
Thanx
Hi
i have forgotten my secuirity code for my phone nokia 1100 can you please assist me with either resetting it or maybe a mastercode?
imei:359399006984754
im need security code for my nokia 1100 my imei no is 35667000/414885/4
security code
Actually i forgot the my security code. Now i want my mobile security code.
Hi
i have forgotten my secuirity code for my phone nokia 1108 can you please assist me with either resetting it or maybe a mastercode?
imei:358364008998062
I forgot the security code of my mobile 1108, please not my mobile no +919703114349 and imei: 35375300/911592/1
i want to restore to factory settings and i forgot the security code of my mobile.how to restore it?
I have nokia 1108. i can't change my phone factory setting restore
i forgot my securitycode give me any solutions
i have problem with nokia 1100 ime imei 350604/40/044896/0 code,0513790
security code forgot ime355352004561888
i have forgot my 1108 keyguard security code. please me to unlock the security code
i have a nokia 1100 mobile But i forgot my security code.so pls help me....
my imei is358849005032964.so pls help to unlock my phone
i need to unlock my security code for my keypad
i forget my access code
hi i forgot my security code for nokia 1100 my imei no is 355690000710862 and the code i got from the net is 2234505545 and it says code error pls help as soon as possible
i want to unlock the security code for nokia 1100 and i dont know the imei, so please help.
nokia 1100
he please tell me how to reset the security code of my cell... the imei no is 353377003603656....
please reply fast...
thanks,
How can I unlock my mobile to use another network sim
clear user settings for nnokia 1100b tracfone
I have a Nokia Type: RH-36 Model 1108b Code:0523935100520QB
IMEI: 01070400/378311/0 and I need to unlock the security code when I am turning on the phone. My son played with it and I cannot remeber my code. I need the master code to reset it...
Thanks in advance
I forgot my security code using Nokia 1100... i want to change my SIM card/mobile number... how can i reset the security code... I already research master security code using my IMEI number, i tried the MSC but didn't work... (code error) please help me to get or reset the security code... My IMEI number is 355689003320455
When I put new SIM in my Nokia 1100 it ask for security code. I don't
remember by security code. I tried by putting Nokia Master Security
code but its not working kindly help me in getting this resolved.
i have forget my security code of nokia 1100 please send security code. IME no is 353753008814441
thankx
I forgot my security code. plz help me
i forgot the security code of my 1108b nokia phone. . and i want to off the keyguard settings since eveytime i lock the keys of the phone, it will always asks for security code. . .what will i do??plzzz have a hand. . thnxxx so mucchhh. . by the way the emei no. is : 010836005407395
Ring Tone of my Nokia 1100 is not working i want to restore factory code my Nokia 1100 IME No. 35707800/037943/3
Shahid Zaidi
actually i forget my possward so pls help me my emi no 35836300/945233/5
my iem no. is 35568900/257299/9. what is the master code?
please help me...for unlock my security code for nokia 1200,imei.359553018687819
i have a mobile but i forset the security code .
IMEI No. 358849007541376
FORMAT MY PHONE AND RESET THE MY PHONE
I have a Nokia 5300 IMEI 356408013788513 and need it unlocked. Can someone help me?
Thanks
356959015604991
1111
my no is 010745008771931
imei:01074500/238539/9 how to unlock my security cord
hi my nokia 1100 security code has been locked and now i want to change the sim but it needs that so please help me my mobile code is 351539006960548 and my mail id is : sadique_hassan@yahoo.com
I have nokia 1100 mobile. I set one security code. But now forget.
I want to set new code How can i ? please help me.
how to reset scqurity code?
hai iam usning nokia 1100 as per the scqurit code missing. how can reset the squrit code .pls give the reply at the earlist.
best regards
sarath
i forgot my security code my imei si 359755005436718 help me please my e-mail is akronnos@yahoo.com
master pin code
to reset my nokia 1100
My IMEI number is 351865010210442....
i was using a security code before but latter forget it. i need a master reset codes to restor my phone to factory setting.
I forgot my securituy code as well and have recieved a generated master code. I enter the master code and I get "Code Error". Am I doing something wrong? I'm told this is supposed to fix the problem. I hope I do not have to go through tech support and have everything erased.
same as above help me
Please tell me to reset my security code.i forgot old one.
i have 1100 nokia mobile.is there any way to reset without go to nokia care?
someone set code at on my security which i dont know so i cant lock my on phone again.help me?
can someone help me to unlock my toshiba W53T..plz i really need an answer..
Hi guyz.
Just wanna ask if anybody already unlocked the locked security keyguard in a Nokia 5300 phone.
If you did, please give me the procedure so I may unlock my phone also.
Many tnx.
Mail me at znar_004@yahoo.com
hello sir plz help me nowmy mobile is nokia1100 model imei no is 358824094117645
nokia 1202 ode error please help me to get or reset the security code... My IMEI number is 351992049555645... the master security code which is generated in internet to reset is 0563378
