A
Anonymous Posted on Aug 28, 2013
H2 code sharp mx3500 - Office Equipment & Supplies
5 Related Answers
Anonymous
  • 126 Answers
  • Posted on Feb 01, 2009
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
pion46
  • 30 Answers
  • Posted on Feb 25, 2009
it is a heater code. The thermostat has blown and resetting the code could cause a fire, but it probably won't do anything, the part will need to be replaced
electronacs
electronacs
  • 19 Answers
  • Posted on Jun 19, 2009
SOURCE: sharp 5320 H2 error code
this is a fuser error message. You must fix the problem causing the fuser to post an error. Then clear the message.
Everett Lin
  • 990 Answers
  • Posted on Sep 12, 2009
SOURCE: Sharp AR-M450N+ Code: H2-01
Hello sir; You may do a reset simulation; press "p" "*" "clear" "*" enter 14 press start enter 0 press start , machine will go back to working condition.
Anonymous
  • 9 Answers
  • Posted on Oct 30, 2009
SOURCE: sharp ar-m160 h2 error code
chack the fusing units the thermistor is open
&thermistor abnormality chack the harness and the
connector between the thermistor and the pwb
use simulation mode(# interaput c interaput )
preas the 14 toclear the self diagnostc dis play
Error code H2-00 on a sharp copier MX-B402 how to reset?
H2 is an indicator that the temperature sensing device is reading open
How to clear error code H2-06
hi
find link for error code H2-06
https://www.youtube.com/watch?v=M6QtVDYFmlo
My Sharp AR-M256 is displaying Code H2-00, how can i remove this?
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
23helpful
5answers
H2 problem sharp AR 5516
sharp ar5516 showing code f2 or h2
7helpful
Sharp 5320 H2 error code
Have MX3500 that fails to print yellow,test prints CM_K.I have changed drums and starter in all the DV units and calibrated machine.However,when SC 50-22 is run Sub yellow front41 error occurs.
It sounds like you must be a tech ? The LSU shutter for the yellow is not opening (most likely) or the drive shaft (of the transfer belt) at the main drive unit has some play in it. The shaft has an e-ring on the end and if it gets worn out it could cause some play in the shaft causing the yellow to "disapear" although this usually results in an error code. Sharp Bulletin mfp-tb-289 addresses this issue.
More than likely the LSU shutter is just not opening. Pull out the primary transfer belt and all drums and dev units. look into the back of the cavity and you will see the link arm (running left to right) that controls the opening/closing of the shutters. Move the link arm by hand and see if all the shutters open. Check the yellow shutter by hand see if it opens manually with ease. make sure all the springs are attached between the shutter arm and link arm. make sure they are all clean.
Hope this helps.
15helpful
4answers
Sharp Fuser
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
