Computers & Internet Logo
Posted on Apr 09, 2009
Code 14 I repeatedly get code 14 error for past 3 weeks and cannot view mail.
Anonymous
Level 1:
  • Contributor 37 Answers
  • Posted on Jun 29, 2009
Anonymous
Contributor
Level 1:
Answers
37
Questions
Helped
23720
Points
87
Whether you use your computer for work or for pleasure, you will find that there are a number of different things that you need to think about. You will find, for instance, that when your computer goes down that it goes down with a thump! All of a sudden, your day comes to a premature end, and any work that you might have had on the table is gone. When you are trying to find a way to rectify this, you are going to find that it can mean hours of research into a number of different things that go into the real functioning of your computer. This article will highlight to you the causes of Windows Error Code 14, and how you can fix the error.
The important thing to remember is that if you run into Error Code 14 or any of the error codes that go along with it, do not panic. Remember, for every problem there is a solution, and all you have to do is to find it. There are many different error codes out there, and the one thing they have in common is that they all have solutions! If you experience Error Code 14, you might be a little bit annoyed or you might even be a lot worried, but the truth is that there is really nothing to get worked up about.
When you are looking at Error Code 14, you will find that what you have in front of you is one of the easiest fixes that you can ever come across. When you are looking at Error Code 14, all that you have to do is to restart your computer. This should be all that it takes to get your computer back to fully functional mode. However, do note that you should always restart your computer the right way. For the most part, you should only hold down the power button for an extended time period when you absolutely need to. The same goes for pulling out the power cord. Otherwise, try a proper shutdown if at all possible.
Remember that this is not a complicated situation, so don't make it harder than absolutely necessary. There are many different things that might cause it, but you will find that when you are considering a fix that there are many options to choose from. When it comes to looking at computer problems, start by dealing with it one issue at a time. You may find that it is easier to deal with than you think.
When you are dealing with Error Code 14, remember that you are going to be looking at something that is much more common and much easier to deal with than you might think. There are many different options in front of you, and you will find that when you are looking at getting your work taken care of that you will need to think about doing a lot of the research that you are considering. Take some time and make sure that you are in a great place to get good results when it comes to taking care of things like Error Code 14. This is a great way to get your computer woes taken care of, so don't miss out!
Click Here to get your runtime errors fixed for free. Logan Albright helps thousands of people optimize their computers through a proper computer check up. He is an authority on troubleshooting computer problems at http://www.pcaholic.com
  • efmcglynn Feb 03, 2011
    I thinbk he is speaking of an error code 14 in yahoo e-mail. I have been getting the same thing- can't access the e-mail.
  • Anonymous Jul 27, 2012
    I beg to differ with you Mr/Ms Bala - for one simple reason: I ALREADY tried rebooting my computer, in addition to following the temporary error14 steps. NONE OF THEM WORK!!!!!!!
Top Yahoo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
