LG LMV1630 Convection/Microwave Oven Logo
A
Anonymous Posted on Jun 17, 2013
Error code F10 - LG LMV1630 Convection/Microwave Oven
E-1 error on my microwave
Take your pick on the MAKE! Google search query on this is
make model error E1
Samsung microwave error codes
https://www.samsung.com > support > TSG01110365
A reference list of microwave error and information codes for Samsung microwaves. ... Close Menu. Open Search Layer; Cart Number of Products : 1; Sign In. Sign In / Create Account · Why ... Unplug the microwave or turn it off at the circuit breaker. If it's possible that ... E-04. Cooking Time Setting Over Error (Convection) ...
How to fix SE Error, 5E error, and E1 Error Fix - YouTube
https://www.youtube.com > watch
5:13 Understanding E1 error, 5E error or SE error. ... Your browser can't play this video. ... SE error ...
Oct. 30, 2018 · Uploaded by Technoo Lab
Can you please assist with Breville mode LMO530 Error E-1 ...
https://www.justanswer.com > ... > Appliance Repair
Nov. 20, 2020 - Yes, this is a system protection fault. The components attached to the main board are checked by the main board when a microwave is in use. 1 answer · Top answer: Thank you! Have a great weekend.
Oyster microwave error code E1 - Fixya
https://www.fixya.com > Forum > Microwave Ovens
Jan. 8, 2018 - No E1 error codes shown for this model of microwave! Have you checked your manual! Oct 7, 2014 GE JES636WK 700 Watts Microwave Oven. 1 ... Hotpoint JE740WY/GY Microwave Oven "Error code e1 ...
Nov. 23, 2019
E1 fault Samsung microwave CE1113f What to do
Aug. 17, 2018
How do I fix error EA1 code on my samsung microwave
Sep. 28, 2014
Oster Microwave E1 error
Mar. 6, 2018
More results from www.fixya.com
F2E1 - Error Code - Over-the-Range Microwave - Product ...
https://producthelp.whirlpool.com > ... > Starts with F2
Apr. 30, 2021 - There may be a problem with the User Interface / Keypad or the associated wiring. Power unit down by turning off the circuit breaker(s) for one (1) ...
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Error code f10 / f1 keep showing
error codes show for a reason - it needs a fix.
get the manual, find out what it is telling u, fix it, and it goes away
How to fix GE OTR microwave F10 error.
The GE F10 error code for a microwave oven indicates a Shorted Touch Screen.
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
5helpful
Error code F2
The error code "F2" that appears on your KitchenAid microwave refers to a keyboard failure/short on the front button panel or loose keypad connector
Attempt the following to clear error:
Check keypad connector for firm connection.
Press "Cancel" after the error code is noted, if error code returns after 60 seconds, replace keypad ( also called touch pad or membrane switch ).
Best of Luck with the microwave.
Kenmore Gas Range model # 362.75491990 F3 error Oven will not hold temp - error message displays and beeps I Replaced the oven temp sensor same issue Is the control panel bad?
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect.
these are some other code error that will help you in case of next time.
  1. Step 1 Press "Off/Cancel" (or "Cancel/Off" depending on your model) to clear the error code. Note the code if it reappears.
  2. Step 2 Replace the touchpad if the code displayed is "F0," "F7" or "F10." A function key is stuck or shorted.
  3. Step 3 Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
  4. Step 4 Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
  5. Step 5 Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is the main control unit. "F5," F6" and "F8 are codes that indicate problems in the ERC functions.
  6. Step 6 Inspect the door-lock assembly and circuit if "F9" is displayed. The door must lock when the oven is in use. If the lock mechanism is not functioning or if the detection circuit is malfunctioning, the stove will display "F9."
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
"F3" codes mean your oven temperature sensor has failed or shorted out. The only thing you can do is to replace the sensor.
Take care.
2helpful
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Top LG Microwave Ovens Experts
Paul Carew
vince
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
