LG make Combimode microwave oven not working
body {
background: #FFFFFF;
margin: 0px;
padding: 4px;
font-family: arial, verdana, sans-serif;
font-size: 10pt;
p {
margin:0px;
padding:0px;
.spwrap
background: transparent url(http://www.fixya.com/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom;
Dear Friends,
The Main Board error codes indicate for most of occurrences that the board
itself has not passed the start up checks that are built in but there are cases
when this is due to peripheral like door safety switches, shorted elements etc. While it is quite worth to explore this yourself if you are a techie and feel confident, please do not attempt if you do not know for sure what you are doing. And yes- DISCONNECT THE POWER PLUG BEFORE YOU ATTEMPT TO REMOVE COVERS and keep it disconnected till the work is over.
Check care fully for the looseness in all the connectors that go to the main board behind operating panel and the door switches, thermal cutouts and magnetron itself. you need not to know about these components, you are just looking for loose connections. If you find any - try to unseat and then seat them firmly. This alone will solve more than 50% problems. Pay attention to the green flat ribbon like cable that comes from inside of operating panel and goes in on large blue socket of main board. You need to pull a blue long tab on the socket itself away from board before you can disconnect the cable, and push it back after cleaning side surface of cable and putting it back in previous place. If this cable is loose, some or all buttons of panel will not work.
There are instances of complaint that the microwave platter starts rotating with or without the sound of internal cooling fan when door is opened - in 99% cases it is upper door switch - it's actuator - dark brown tab which comes out when the door is opened is failing to come out fully. You may attempt to set it right yourself if you are a good hand in repairing small components or obtaining exact replacement is not difficult from repair shops. Its technical name is micro- switch and you either will need to tell the size and no of wires coming out of it or the best is to remove the same and show it in the shop to get exact replacement. In my case the internal leaf spring needed stiffening and it worked fine. Similarly other door switched also cause unexpected things but usually it is small problem.
Although if you leave power plug connected and power on during nights, and fine one fine midnight that the appliance is making sound, usually it does not mean the microwaves are working inside. It could be opposite of the thing described above. But - why to leave it on during nights? Best practice is to unplug it when not in use. This will certainly protect your appliance from voltage surges that are known to damage electronic appliances often.
One reader quoted non functioning of panel switches when a through wet cleanup was attempted- It is nothing but some how water or soap solution got inside the layers of panel switches which happens to be membrane type. Some switches may start functioning (usually the upper ones when water moves downwards due to gravity) after some time . The best possible safe solution would be to remove water by gently using a hair dryer on outer surface to heat it up so that the water in internal layers evaporates slowly bringing all buttons to previous level of functioning. Take care not to heat-up too much or the plastic panel may deform - use a 6 inch distance at medium heat setting and your patience. It might take a while but half an hour work is worth against replacement. If you are more confident- you may attempt to peel off delicate layers of switch board, clean them and reassemble back using thin double sided tape. Mind that even though you are not removing cover, appliance is to be disconnected from mains first.
Hope it helps.
Basant
