The PHP Group PHP Logo
Posted on Mar 19, 2009
Php counter im trying to add a visitor counter to my homepage i downloaded the script but not sure what to do and where to put things to get it running this is the counter script... // Connect to server and select database. mysql_connect(''$host'', ''$username'', ''$password'')or die(''cannot connect to server ''); mysql_select_db(''$db_name'')or die(''cannot select DB'') $tbl_name=''counter''; // Table name $sql=''SELECT * FROM $tbl_name''; $result=mysql_query($sql); $rows=mysql_fetch_array($result); $counter=$rows['counter']; // if have no counter value set counter = 1 if(empty($counter)){ $counter=1; $sql1=''INSERT INTO $tbl_name(counter) VALUES('$counter')''; $result1=mysql_query($sql1); } echo ''You 're visitors No.'' echo $counter; // count more value $addcounter=$counter+1; $sql2=''update $tbl_name set counter='$addcounter'''; $result2=mysql_query($sql2); mysql_close(); ?> and this is mode homepage code.. LOGIN Wanna find out all the latest upto date infomation on the AbZoRbeD network, Then check this out. Dont idle for no reason join in the game and have a little fun battling against the other players. Use this forum for discussing all kinds of topics you must be registered and logged in to access this area if you would like to register Click Here Contact Us © AbZoRbeD.net 2007-2009 any help would be grate :)
  • 1 more comment
  • d_howley Mar 19, 2009
    sorry i forgot to say that i have that all setup
    just didnt want my username and password getting out :)
  • d_howley Mar 20, 2009
    should the path to the counter.php go in here i got the counter.php in a folder called counter because i keep getting the error ... PHP Fatal error: Call to undefined function counter()
    i did what you said now im just getting an error .... Fatal error: Call to undefined function counter()
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on May 09, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
14654
Points
9
You might want to note that this is not the most effective manner of creating a counter in PHP. On a few of my websites, I find it is much more effective to simply create a text file, eg. counter.txt and have PHP read that every time the page is loaded, instead of running a MySQL query. Then, have PHP also update the counter.txt file by adding 1 to the number already listed in the file and read to the user.
Dubravko
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Mar 19, 2009
Dubravko
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
15776
Points
12
These lines
say that you need mysql database. user name, password and table in that database called counter....
So if you do please change parameters if you don't, dont yuse this script, use just some site with free simple counter for your site, which is maintained on their site
  • Dubravko Mar 19, 2009
    Then, the best way is to wrap it into some function, include that code in homepage and call function from somewhere in page where you want it to be seen , for ex.
    function counter()
    //copy counter code here
  • Dubravko Mar 20, 2009
    See this page for includes, don't change function call.
    http://www.w3schools.com/PHP/php_include...
    in your case
Top The PHP Group Computers & Internet Experts
Rob Hill
Rob Hill
Nikole Brown
Nikole Brown
Syed Bilal
Syed Bilal
Are you a The PHP Group Computer and Internet Expert? Answer questions, earn points and help others
