Refrigerators Logo
A
Anonymous Posted on Apr 30, 2013
Error code i have a refridgertor model number HB21FC45NS keep getting error code E5
5 Related Answers
Anonymous
  • 2072 Answers
  • Posted on Jan 25, 2008
SOURCE: Error codes on xerox 212
An E5 most frequently comes from the door connector . When you open the right side on the upper left there is a black connector. Those contacts may be dirty or bent. Carefully clean and reform if necessary. I will send you some other info to follow.
Also if you take the copy cartridge out and and clean all the contacts inside the machine you can see, it may also correct it.
Recurring problem with E5. Door connector has been replaced, contacts on Interconnect board are clean and shiny, but interlock connection still not reliable. When you remove the rear motor cover and press on the door connector, the E5 goes away and the fuser starts to warm up. The door connector is mounted loosely to the door to allow it to locate itself with the interconnect board when the door is closed. If it is too loose, the connector will not make good enough contact to complete the interlock circuit
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 06, 2009
SOURCE: what is a E5 error code in a micro over model
An "SE" error would be a shorted membrane keypad.
I'm not sure about an "E5" error.
You would have to consult the "mini-manual" or technical sheet inside the microwave, usually located behind the control panel or hidden inside the area behind the grille. It may mention an "E5" error.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If it is an SE error this is a problem that's pretty easy for the homeowner or a friend to do himself. And you can save $200 or so.
I'll tell you what the DIY options are and you can decide if you'd prefer one of those or to call Sears/Kenmore for service:
Take your control box off as in the video at our site, peel the old keypad off as in this handy guide with pictures , clean the surface, stick on the new keypad
order by part number here DE34-00233T SWITCH MEMBRANE $20.60 membrane keypad
(We can do this job for you for a total of $64.95, but as you can see, the other two options are more practical and economical)
Take your control box off as in the video at our site, disconnect the keypad strip as shown here, move your circuit board to the new frame, reinstall
order by part number here DE94-01647D ASY CONTROL PANEL $31.77 control panel frame with keypad
Take yours off as in the video at our site, then install the new one
order by part number here DE94-01648D ASY CONTROL, BOX $58.98 complete control panel assembly with frame, keypad and circuit board
Anonymous
  • 56 Answers
  • Posted on May 15, 2010
SOURCE: e5 error on printer
hi..make sure you change the right cartridge..or try clean the cartridge chipset using clean tissu
Anonymous
  • Posted on May 16, 2012
SOURCE: error code E5 for model : MOB-10KDCHR
I have Boston Portable ac MOB-10KDCHR can not find a parts number for the drain cap and drain hole (rubber plug)
jeff5may32
  • 1258 Answers
  • Posted on Jan 05, 2015
SOURCE: 3 outdoor system brings same error code E5 02. Model rxyq12t7y1b x2 & rxyq14t7y1b. Ran test, finished test. Ran it fo 4hours after finishing test, then it brought up error code E5 02.
Not good. The Daikin Inverter models use current sensing to tell when the compressor is straining too hard, and set this code when something is wrong. If you are under warranty or not properly qualified to troubleshoot this compressor lockup symptom, I would highly recommend having a factory tech come out and have a look at your system.
Here\'s a link to the manual: http://www.icglimited.co.uk/library/web/1.%20Daikin/1.%20VRV%20Manuals/3.%20Installation/Outdoor%20Units/RYYQ-T%20RYMQ-T%20RXYQ-T%20Installation%20Manual%20(4PEN329765-1C).pdf
Daikin also has a ton of other tech sheets and training materials that are generally only privileged to factory techs. They describe troubleshooting and inner workings of the machines much better than the install guide.
Please mark my answer as helpful.
Top Haier Refrigerators Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
