Panasonic KX-T7730 Corded Phone Logo
mekonnen kebede Posted on Apr 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i program kx7730 using pbx - Panasonic KX-T7730 Corded Phone
Carl Navarro
Level 3:
  • Panasonic Master 2,460 Answers
  • Posted on Apr 11, 2013
Carl Navarro
Panasonic Master
Level 3:
Answers
2460
Questions
Helped
1180370
Points
7314
A 7730 is a phone. Do you mean program a system USING a 7730?
Half questions don't get full answers.
Can the Panasonic KX-T7667 phone work with the Panasonic KX-TES824 PBX?
Yes, the Panasonic KX-T7667 phone and the Panasonic KX-TES824 PBX are compatible.
The KX-TES824 should be able to accommodate different handsets because it is made to work with a variety of Panasonic phones, including the KX-T7667 model.
You must connect the KX-T7667 phone to an available extension port on the PBX and configure it with the proper parameters using the PBX programming software or a web interface in order to add the phone to your current PBX system.
It's vital to keep in mind that the KX-T7667 is a proprietary phone made just for Panasonic PBX systems and might not work with other phone systems or third-party hardware.
2answers
Red alarm light on Panasonic KX-TAW848 PBX after power surge
Please use your manual to factory reset your phone and then use the manual to set the phone up as you initially did in order to overcome this issue.
Thank you.
How to i turn on Caller ID on my panasonic kx-dt321 phone ? When an incoming caller rings it just says Line 1 . No number is displayed.The 3 other similar phones all have caller ID when someone rings
If I understood users manual which I found via internet,it is digital system for PBX,so it means you can use it 100% if it is programed thru PBX system,so you need to call your IT personel to program it
for you.
Unblock phone calls from phone
need more details on problem.
do you have access to programming the pbx?
do you mean that others using the pbx cannot call?
are they allowed to access a dial tone, but cannot dial out?
To enable caller ID phone tes824 through 7730
Hi
I am using Caller ID software and I want to configure PBX to send the log call to our program when an incoming call, then when I answer the call and another after the end call, is there a way to define the PBX to do that
note : PBX now send call log only after the end call.
We used to have a guy come in whenever we had phone problems but he retired. One of my co-workers somehow tried to transfer a person to one of our other locations but in the process have put lines 1 and 5...
When you transfer a call from the outside to an outside place, it will use two external lines for the duration of the call. Sounds like there the PBX is not configured for "disconnect supervision," (DS) meaning that it can't detect when the call finished on either side, so it holds those lines in use. Even if you set DS up on the PBX, the telephone company be sure the lines are programmed for COD (clear on disconnect).
If you do external transfers, you need to set up disconnect supervision on the PBX and COD from the telephone company.
This will probably involve the services of a professional, unless you are comfortable navigating the
internal menus of the PBX.
You can clear the lines by disconnecting the amphenol connector for the outside lines for a few seconds and reconnecting it (which will disconnect all outbound calls) or by rebooting the PBX.
Panasonic KX7730, change display mode from Date to Time
What? The second soft key under the display is labeled INFO. It has 3 modes. If you are trying to program time, then you just press NEXT when you're in programming.
Carl
2answers
Registration of ps in pbx
i have a problem in panasonic pbx TDA 620 which tells all extensions are buzy when hhave been called and the stat of the card nothing neither red nor green solve this problem for me please thanks as always for your help
Top Panasonic Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Axel Gringmuth
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
