F02
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and
F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4
minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is
running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Hi
This code indicates an electronics
communication problem with the washer.Please check this link to get a detailed
idea related to the lists of codes and the resolutions to them:-
The error code F28 means one or both of these
parts are bad.
Motor Control Unit ,Microcomputer Machine Control Unit .
It would be a good idea to order both, as both components have been problematic
for error code F28.
Please get back to us if you have further
query or else please accept the solution.
Thanks for contacting fixya.com
