expert Posted on Feb 19, 2013
What is the solution to the error code c0500 printer docujet 4021
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Jul 13, 2009
SOURCE: I am getting an error code C0500.
Depends on the model of you Konica Minolta. The CO500 is usually related to fusing temp. It's possible that a power spike or a thunder storm that knocked out power to the building would caused this.
firecontrol7
Norman Weimar
  • 7080 Answers
  • Posted on Jul 25, 2009
SOURCE: error code c0500
C500 is a fuser code, the hot part of the machine, the fuser fuses the toner to the paper, so that the toner does not smear off. But to solve this must have the model number. As each series of machine has a different way to reset machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1234567890mi
  • 58 Answers
  • Posted on Aug 07, 2009
SOURCE: iR 5870Ci Errors: E000748-4021 & E000020-03a8
E748-4021 means the SERROR signalof PCI has been detected
solution:disconnect and then connect PCI board if the fault persists ,replace it or the main controller pcb
Anonymous
  • 55 Answers
  • Posted on Nov 09, 2009
SOURCE: access service mode on copier docujet 3016F
If you can you will need to get it, the mirrors in the scanning unit.
good luck
Cogz
Chris Coughlin
  • 1326 Answers
  • Posted on Feb 03, 2010
SOURCE: minolta coppier 3000 has an error code c0500 and
The error code is saying that there is a problem with the fuser section. Did you have a power surg resently? If so you may be able to reset it. If not you may have a blown fuser lamp or thermal fuse or the thirmister. You may have to have it fixed before it resets.. The reset botton is on the main controler on the back of the copier
Well hello i need a user manual pdf for docujet 4021
Hope this is what your looking for..Cheers Pete
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjB84vtv5nSAhUJjJQKHcJNB3IQFggbMAA&url=http%3A%2F%2Fpdfstream.manualsonline.com%2F0%2F0b24053d-5c32-4480-9ed5-8412bb470b80.pdf&usg=AFQjCNGExhnpomDWoDp3MGn4big5DlGWYQ&cad=rja
1helpful
C0500
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
1helpful
How to clear maintenace call M2 in docujet 4021
go utlite--stop--00--stop--01--chear data--supplise--rest--rest
turn off/on
and it well work
sorry for bad eng
Error code 4021
4021 indicates Print job power failure
When there are running jobs, perform the job in error again after the completion of the running jobs.If the error still occurs, turn the power OFF and then back ON, and perform the job again.
3helpful
The machine di251f is saying contact your technician with code error c0500 please help
C0500: Warming-up Failure
error code c0500, checked lamp and thermo fuses, checked thermistor ok. reset machine
46helpful
3answers
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
85helpful
4answers
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
