Health & Beauty Logo
A
Anonymous Posted on Feb 03, 2013
E11 error code - Health & Beauty
What does E11 error code on Bloomberg KQD 1250X fridge means ?
The E11 error code on a Bloomberg KQD 1250X refrigerator typically indicates a problem with the refrigerator's evaporator fan. The evaporator fan is responsible for circulating cool air throughout the refrigerator compartment. If the fan is not working properly, the refrigerator may not be able to maintain the proper temperature. The E11 error code may also indicate a problem with the fan's wiring or control circuit. It's recommended to check the wiring to the fan motor, ensure that the fan motor is not blocked and check the control board for any damage or error. If you are not comfortable troubleshooting the issue yourself, it is best to consult a professional or contact the manufacturer for assistance.
1helpful
What does error code E11 on Bloomberg KQD 1250X fridge means?
The E11 error code on a Bloomberg KQD 1250X refrigerator typically indicates a problem with the refrigerator's evaporator fan. The evaporator fan is responsible for circulating cool air throughout the refrigerator compartment. If the fan is not working properly, the refrigerator may not be able to maintain the proper temperature. The E11 error code may also indicate a problem with the fan's wiring or control circuit. It's recommended to check the wiring to the fan motor, ensure that the fan motor is not blocked, and check the control board for any damage or error. If you are not comfortable troubleshooting the issue yourself, it is best to consult a professional or contact the manufacturer for assistance.
M frigidaire washer model gltf2940fs1 shows me a e11 code
Thanks for your post, friend!
From my understanding your Frigidaire frontload washer, GLTF2940FS1, is displaying an "E11" error code. Typically, "E11" stands for fill time too long which means you could have an issue within your pressure sensor or control board. I would recommend a reset on your washer and that can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue you may want to consult with a technician for proper diagnosis. I hope this is helpful. -Matt
2answers
Eternal hot water heater error code e11
I cannot find what e11 means but it seems most people have just unplugged it an it came back on. Code goes away.
I have a Frigidaire affinity washer error code reads E11. Unit immediately pauses after activating start. Troubleshooting door ssitch revealed resistance was 1320 ohms. I was told 1500 ohms should be...
Good Morning Neil, thank you for your post!
Typically, error code E11 indicates that the water fill time is too long. This could be due to a faulty valve, clogged valve filters, kinked inlet hoses, or low water pressure supplied to unit. Also, if the drain hose is installed too deep into the house drain pipe the water may syphon as it fills. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
1helpful
E11 code on the dispay
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
My oven is beeping on an E11 error code on my electrolux range. How do I stop this?
E11 indicates a communication error where a technician needs to diagnose the control board.
E11 error code fios motorola box
Eb 11 - Invalid unit address / Resettable only at factory / Replace the DCT
Here's a site with a list of fault codes:
How to use Motorola DVR Boot Error Codes
39helpful
2answers
Error code E11 on hoover washer dryer vhw854d
Top Health & Beauty Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Rob Hill
Rob Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
