Panasonic PANAFAX UF-6000 Fax Logo
Posted on Oct 01, 2012
Code = 021 - Panasonic PANAFAX UF-6000 Fax
Turboion croc classic flat iron bc-cr1. When I turn on, error code 021 and it shuts off. Is there a fix?
Error code 021 on a Turboion Croc Classic flat iron indicates a problem with the temperature sensor. This error can prevent the flat iron from heating up properly and may cause it to shut off unexpectedly.
To fix this issue, you can try the following steps:
  1. Turn off the flat iron and unplug it from the power outlet.
  2. Use a small screwdriver to open the back cover of the flat iron and locate the temperature sensor.
  3. Carefully inspect the temperature sensor for any signs of damage, such as bent or broken wires, loose connections, or burnt components.
  4. If you notice any damage to the temperature sensor, you will need to replace it with a new one. You can purchase a replacement temperature sensor from Turboion or from a third-party supplier.
  5. Once you have installed the new temperature sensor, reassemble the flat iron and plug it in. Turn it on and check if the error code 021 is still appearing.
  6. If the error code persists, you may need to contact Turboion customer support for further assistance. They will be able to provide you with more detailed troubleshooting steps and help you resolve the issue.
Dec 04, 2022 • Irons
Renault Scenic radio code needed. Model No: RENRDW 131-10 RENRD 0340211 111 Prod No: FD 060 440 021 111 1 8200 300 858 TR 460 Thank you.
Renault Scenic radio code needed. Model No: RENRDW 131-10 RENRD 0340211 736 Prod No: FD 060 440 021 1736 8200 300 858 TQ 349 Thank you
13helpful
3answers
Error code 021
Press
Function
7
monitor slowly 4 times
6
scroll down to SHIPMENT SET
set
wait for the fax to initialize and come back to READY
2helpful
Brothers sewing machine ls 1520 what all parts came with this machine.did it come with a button hole foot
I hope this is your machine, check it out
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_1520_EN_270.PDF
ACCESSORIES
1 Buttonhole foot (1 pc.)
2 Zipper foot (1 pc.)
3 Button sewing Foot (1 pc.)
4 Needle set (regular single needle No. 14) (3 pcs.)
5 Twin needle (1 pc.)
6 Bobbins (3 pcs.)
7 Darning plate (1 pc.)
8 Screwdriver (1 pc.)
9 Extra spool pin (1 pc.)
Parts code for zigzag presser foot: 138135-051
Foot controller: X57319-051 (110/120V Area)
XA6422-021 (220/240V Area)
XA6412-021 (U.K.)
XA6414-021 (Australia, New Zealand)
The above accessories are stored in the accessory bag inside the
extension table. These accessories have been designed to help
complete most sewing tasks.
I have a panosonic uf-4000 fax it keep reading error 021. It is not listed in the book. What does this code mean
021 is a fuser error, that can either be reset in service mode or i may need a part in the fuser. Best to call a local service rep.
1helpful
2answers
Nokia 2630 security code unlock
for imei :356997/01/611179/8 try inserting the code 5745474700,4050342265 in place of the security code ...
if you are not successful in that then just dail *#5745474700#,*#4050342265# .........
for imei :352046/021/549443/3 try inserting the code 3345110156,4604222314 in place of the security code ...
if you are not successful in that then just dail *#3345110156#,*#4604222314#......
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Jul 13, 2008 • Cell Phones
2answers
Panasonic uf885 error
Same here. I replaced the fuing unit but he error code 021 still is present.
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
