Bosch AquaStar 2400ES-NG  Logo
Jennifer Posted on Jul 30, 2012
C7 is code - Bosch AquaStar 2400ES-NG
Steven Foerst
Level 1:
New Friend:
  • Contributor 52 Answers
  • Posted on Oct 17, 2013
Steven Foerst
Contributor
Level 1:
New Friend:
Answers
52
Questions
Helped
33199
Points
78
C7 is displayed when the primary fan (the one in the middle just under the copper heat exchanger) does not spin or the computer does not recognize that it is spinning. There is a plug on the back of the fan. Make sure it is plugged in all the way.
This also happens when the computer gets damaged because the unit is plugged in to an extension cord, power surge or poorly adjusted combustion (most contractors lack the proper equipment to adjust the flame on high efficiency equipment). I have been to over 500 tankless water heater installations and found every one of them were not adjusted at all! It can also be a damaged fan caused by an improperly installed exhaust pipe.
Bosch2500LP tank less HW flashing code C7 no hot water. What to do?
C7 is a fan code, either blown fuse on the board, bad board, or bad fan. Fan needs 24VDC, if you get voltage to your fan and still have C7, the fan needs to be replaced. If no voltage to the fan, its either the fuse or the board.
Default code C7 76
Hello Howard
1) Copy following link for troubleshoot resources including error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) Unknown if this is new install or older unit with new problem
This error code can be failed PC board
3) Feb 2013. Add a comment and say what you find
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
C4 76 error code on richland waterheater
Richland tankless is made by Rheem.
C7-76 is communication fault with remote.
Turn off power at remote and wait 5 minutes, turn power back on at remote, and see if problem clears.
If problem continues, read below:
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, typical maintenance manual:
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Tankless water heater, more than any other type of heater, need to be maintained.
Maintaining tankless will probably not affect C7 76 fault code, but can prevent many other common error codes.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
1helpful
No hot water error codes 76, C4,C7
Before calling service tech, open following links for Rheem troubleshoot resources including rheem chat, error codes, possible maintenance and service manual.
Error codes are considered start-point for troubleshooting.
Multiple error codes can mean PC board failure.
http://waterheatertimer.org/pdf/Error-code-13.pdf
Rheem tankless propane hot water heater error code C7. Cant get hot water. It keeps shutting off and then once turned back on wont work and gives the C7 code. What does it mean?
Use following link for Rheem tankless troubleshoot: http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
I believe error code C7 is same as error code 76
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
My tankless is shuting off or flashing C4 and/or C7
C7 andC8 plus 76 flashing on my remote
C7 C8 76 error code, can be PC board fault, and/or communication fault with remote.
Open link to read one possible solution:
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
Add a comment with your experience so others with same-similar problem can benefit.
Can't find manual & have a C7 error code on a Rheem tankless water heater model # rtg-74pvm-1.
need to contact rheem what you can do until then is remove the control wire it will run until parts ship out
Paloma water heater error c7 13
I have a code showing C7 13 the heater runs for about 2 to 3 mins then shuts off. Any suggestions?
Top Bosch Water Heaters Experts
john h
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
