I have the volume on htc one set on lowest setting. Using earphones to listen to books or music, the lowest setting is still too loud. I have changed the "beats" enhancement setting to off, but it's still too loud. Anything else I can do to decrease the volume, before I go out and buy a headphone set with a volume control (which may or may not work)?
SOURCE: VOLUME NOT LOUD ENOUGH
If you would be willing to modify your phone slightly (software tweaks) this guys has an app that will help:http://montecristoff.webs.com/index.htm
There is simply a sound limit in the software that stops it from going louder.
SOURCE: HTC Touch Pro Won't Vibrate
So you having problem with vibrate capability?
Try this:
1. Make sure your phone not in charging (it won't vibrate for several phone like e.g. NOKIA)
2. Have you dropped it? If yes, immediately contact the customer service.
Hope this will help! PM me if there's any questions =]
SOURCE: headphone symbol though no headphones in so cant talk to people
It sounds like your device may be paired with a Bluetooth headset. Try turning off bluetooth connectivity and see if that fixes the issue.
SOURCE: HTC inspire 4g. When I
Hello.
Remove your SD card and see if it is still acting strangely. If it is, then you need to reset your unit.
Menu / SD and Phone Storage / Factory data reset.
(note: All the files you stored will be deleted)
