Computers & Internet Logo
tyson montrucchio Posted on Jul 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code -36 - Passport Western Digital Computers & Internet
Brian Sullivan
Level 3:
  • Western Digital Master 27,725 Answers
  • Posted on Jul 03, 2012
Brian Sullivan
Level 3:
Answers
27725
Questions
Helped
5776703
Points
79191
Is it error code -36 or just eror code 36
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
hope it helps
How to Fix Windows Error Code 36?
When you use your computer and try to use an installed peripheral device, the Windows error code 36 can occur. Windows allocates computer resources to each device and sees a conflict in the resources that this device tries to use and can therefore not interface with the device.
Fix : https://www.errorcodeexpert.com/how-to-fix-windows-error-code-36/ or Call us : +1 (866) 748-5444
1helpful
Getting error code 36 hour duration
I appreciate your inquiry, friend!
Based off what you have described your Frigidaire freezer is displaying an error code of 36 hours. Normally it will display that once power has been restored, it is indicating that the freezer has been without power for 36 hours. Hold the "alarm reset" for 3 seconds and that should help clear out the code. I hope this is helpful. -Matt
What does code 36 mean
Error code 36 does not show in Rheem tankless manuals.
Copy following link for general troubleshoot and error codes, and Rheem contact information:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error code 36 does not show in any resource, including 2008 service manual, or 2012 product manual.
Check that remote control display is illustrating the correct number.
For example there is error code 35.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2answers
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Error code 36 when transferring photos to harddrive
According to Microsoft, error 36 is:
"ERROR_SHARING_BUFFER_EXCEEDED
36 (0x24) - Too many files opened for sharing."
There may be many causes for this. Do a virus scan and run the registry repair tool from this download link:
http://www.windows-error-repair.org/tools/regcuredownload.php
Run the tool, press the scan button and let the tool clean and fix your registry.
Good Luck!
2answers
Error Code E03-36
pull out toner bottle from machine
shake it well
reinstall it
power off then on
code will bi reset
1helpful
3answers
2helpful
2answers
MacBook Error 36
Error 36 means “I/O error” (input/output error) and does not explain what the cause of the problem is, sorry.
Check your Mac for bad blocks you can use Disk Utility.
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Narseman
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
