Brother CS6000i Computerized Sewing Machine Logo
A
Anonymous Posted on Jun 20, 2012
F3 error code
Error code F3 is coming up. Machine made a clicking noise and the E6 error code came up a couple times before the F3 code, and no threads were tangled.
5 Related Answers
Anonymous
  • Posted on Jul 30, 2009
SOURCE: machine is telling me E6 error but there is no thread tangled
I am in the middle of fixing this same error. I phoned Brother service in Manchester and they are spot on. Give them a try, they talk you through the problem and suggest things to do to narrow down the cause. Make sure you have the model and serial number as this saves time. In extreem cases you can send your machine to them by parcel post and they will look at it free of charge and then give you an estimate for any repairs needed. If you decide not to go ahead, you can elect to have the machine returned to you for the cost of the postage.
In my case I bought the machine second hand off of E-bay and was getting the dreaded tangle/needle message. I phoned the service department and I was told to thread the machine up and switch on. Then they give you several things to try. Essentially you need to get someone to press the start button while you immediately turn the handwheel forward gently and smoothly.
If this stops the message coming up then you must suspect the motor or its fuse. In my case, it would seem the machine had been dropped as there was a hairline crack in the circuit board which stopped the power getting to the motor.
Anonymous
  • 11 Answers
  • Posted on Apr 08, 2010
SOURCE: I keep getting an E6 error message - tangled
It could be that the bobbin is being put in upside down check to make sure that you do not need a bobbin with a magnet on one side. also make sure there is no thread tangled inside the bobbin housing it will cause the timing of the machine to be off and cause issues with your needle picking up the bobbin and thus cause a mess inside you bobbin housing
Anonymous
  • 1788 Answers
  • Posted on Oct 11, 2010
SOURCE: The machine is making a grinding noise and giving
I would call Brother at 1-877-276-8437, it may be a malfunction. They will be able to advise your where to take it for authorized service. Good luck
Anonymous
  • 1788 Answers
  • Posted on Jan 11, 2011
SOURCE: I am using my Brother
What kind of thread are you trying to use? Is it a decent fresh thread? If, it is old, throw it out and buy some fresh quality thread. Usually, cheap thread is the problem.
Anonymous
  • Posted on Aug 03, 2011
SOURCE: E6. Motor locked up because the thread is
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Top Brother Sewing Machines Experts
Paul Bade
Rommel Balcita
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
